Forgotten savings
The Hay Slow Cooker (hooikist) was invented in the Netherlands around 1900 and especially popular during the Second World War, when heating fuel was scarce. Nowadays it is forgotten, which is a pity as it can save up to 80% on cooking fuel costs. The Hay Slow Cooker is ideal in temperate climates for long cooking food in liquid such as beans, pulses, rice, grains, stews with meat like goulash, chicken pots like coq-au-vin, potatoes, porridge, soup, etc.. In warm climates a solar cooker is probably more practical. Do not slow cook fresh vegetables, steaming is the best way to preserve vitamins. The Hay Slow Cooker is easy and cheap to make and your food will never burn! It is also said that the Hay Slow Cooker is perfect for cooking large quantities, as the heat is spread more equally than on a stove.
How it works
A pot on the stove requires continuous heating because it is constantly losing heat to its surroundings. A Hay Slow Cooker wraps around a hot pot and insulates, thus keeping the heat inside much longer. Only 20% of the normal cooking time on the stove is needed, the hay will do the rest of the cooking for free.
How to use the Hay Slow Cooker
Boil the food on the stove one fifth (1/5) of the normally required cooking time up to a maximum of 20 minutes. Transfer the pot quickly to the Hay Slow Cooker. Leave the pot 3 times the normally required cooking time in the Hay Slow Cooker. Foods that require a very long cooking time can be reheated shortly to boiling point on the stove and then returned to the Hay Slow Cooker to continue cooking. Reheat the food to boiling point before serving to be sure of food safety.
Filled almost to the brim with 4 liters (1 gallon) of boiling water and beans, the fully cooked contents of the pot were still 70 degrees Celcius / 158 degrees Fahrenheit after staying for 6 hours in the hay slow cooker of this instructible. These figures will vary depending on the size and model of the pot and hay slow cooker.
Remove these ads by
Signing UpStep 1Tools and materials
To start, you need a large cooking pot with a well fitting lid. The hay and fleece cover will be custom made to fit this particular pot. Preferably the knob on the lid and the handles should protrude as little as possible. A long handle as on a sauce pan is not suitable.
Materials
� cotton fabric ( a few old shirts, a bed sheet)
� fleece (from old sweaters)
� cord or ribbon, about as thick as shoe laces
� newspaper or other paper for templates
� hay (dried grass, I used a 1 kg pack of rabbit fodder, 1.20 Euro / 1.60$ at the local supermarket). Straw, which is thicker than hay, is less suitable because it insulates less well.
Tools
Sewing machine, sewing needle, thread, scissors, safety pin or special needle to thread the ribbon/cord, pins, measuring tape
Skills
Only beginners sewing skills are needed. Except for the circumference of the small circle for the rectangle, the measurements need not be very precise. A few centimetres (around 1 inch) more or less do not matter: just fill the pillows with more or less hay for a good fit around the pot.
Works like a miracle. Never burned rice anymore and my gas-bil is really low.
Yeah, one day I will make the hooikist but for now I can tell you the principle works
