Head Gasket Replacement on '91 Honda Civic
Head Gasket Replacement on \
This is my first Instructable... Please comment below if it needs further editing. Videos can be seen by opening the video URL in your media viewer.
Here's my experience with replacing a new head gasket on my '91 Civic. But first, some background:
This is a great car! It ain't pretty but it gets almost 40mpg on a good day. About a year ago, it failed to pass several emissions tests. My mechanic told me that the pistons needed new rings. Because the engine would be in pieces, and because of the expense and effort invested already, I agreed to have the water pump, timing belt, and head gasket replaced. Afterwards, the car passed emissions with flying colors and ran very well until recently.
Several weeks ago, the engine began to overheat erratically. After googling the problem, I personally replaced, in ascending order of expense, the radiator cap, the thermostat, and eventually, the radiator, which was very old. Because the problem was intermittent, it seemed that each part replacement solved the problem. I hoped it wasn't the water pump because I knew that would be a huge pain to replace.
In the end, some white smoke and serious engine vibrations told me that it was not the water pump but some cylinder/coolant related problem. I was afraid that it was a cracked cylinder which would have meant replacing the engine block, which didn't seem worth the expense on a 16 year old car with 174,000 miles on it. So, I went into the engine bay prepared for the worst. What follows is my experience and illustrates why your trusted mechanic can't always be trusted....
Step 1You are probably NOT a mechanic....
.....nor am I, but, judging by the cavemen that have worked on my cars in the past, I figured that this shouldn't be beyond me. I've repaired/replaced most things in a car that don't require specialized and expensive tools. Be forewarned, however, if you're not relatively strong and at least a little mechanically inclined, get someone who is and have them help you.
To get started you might want the Haynes repair manual, and a couple of impact-wrench quality sockets; I broke a Craftsman socket trying to remove the header pipe from the exhaust manifold. Having a digital camera might also be useful for recording your progress as well as problems you might encounter. You MUST have the following:
About 16hrs total total time: In addition to putting the valve assembly back on the head, putting the timing belt back on MAY require that you remove belts, pulleys, and an engine mounts, just as if you would replace the water pump. In fact, if it's old, plan on replacing that water pump. Also plan on changing the oil a couple of times as well as flushing the radiator. Sorry, but it's a big job, which is why a $30 part requires about $1,000 worth of labor. Don't bother taking shortcuts; I tried to lever the timing belt back on to the valve pulley to avoid the proper way and ended up ripping it. Plan on spending the time to do it correctly....Sorry! But you might as well learn from my boneheaded efforts.
Several Jackstands: You will need these to elevate the car and get deep underneath.
A torque wrench up to 70ft-lbs.: Don't even THINK of tightening the crankcase bolts without one!
A breaker bar: Some of your exhaust system bolts were likely tightened by Lucifer himself. A breaker bar will help release his grip.
3/8" and 1/4" drive socket sets: Also with various extenders, adapters, and universal joints.
Band-Aids: If you don't know why, you'll see soon enough.
Call the local parts supply places for expertise. The counter help might include gals/guys who are going to mechanic school or have rebuilt engines just like this one. Their help may be invaluable.
17 comments
May 9, 2011. 4:00 PMmarkey1979 says:
Antifreeze came in from the cylinder head. When you removed the cylinder head, the residual coolant deposited in the cylinders. This is very normal. Alternately, after removing the exhaust manifold you can drain the block and head of coolant by removing the rather large plug in the block behind the exhaust manifold, but I would not risk damaging it due to its age!!
Civic's, like yours, sometimes crack cylinder heads, but usually its just the head gasket. An easy identifier is when the car is overheating, and ESPECIALLY white smoke, then its the head gasket. When the head CRACKS, the first indication will be oil mixing in the cooling system, I.E. evidence in the radiator
Jun 29, 2009. 7:07 PMzacparks says:
This is not a distributor, this is a waste spark coil
Aug 18, 2010. 12:00 PM000000 says:
(removed by author or community request)
May 9, 2011. 3:52 PMmarkey1979 says:
@zacparks
...No dude, it is definetly a distributor. distributorless ignition did not start on Civics until 2001, at least here in the USA.
Feb 20, 2010. 3:41 PMYerboogieman says:
My car doesn't have pistons! Or a large series of batteries.
Jun 25, 2009. 4:14 PMMike Mattson says:
I did this job a couple months ago with the help of this tutorial. My experience: I used the Honda replacement MLS (multi-layer steel) gasket. I didn't use the recommended replacement bolts. (they were about $95.) I did use the newer three stage torqueing procedure. I didn't need to remove the radiator. (very glad) It took about 6 hours, I guess. Thanks!
Apr 11, 2009. 10:36 PMeric m says:
The breaker bars annoy me. I just uses a pipe fitting over a socket wrench. The best option for frozen bolts and nuts is OXY-Acetylene welding torch. Heat it up and it will expand. If it still doesn't come off then heat it red hot then use your bar and if that still doesn't work then oxy cut it off and weld a new thread,.
Apr 11, 2009. 10:32 PMeric m says:
I tried removing the head gasket on an 87 model but the impossible angles to get at those damn bolts made me quit. kinda sad about it still.
Mar 8, 2009. 4:13 AMef_jay says:
this is a dpfi model, no carb on it, thats the intake plenum :P
Mar 8, 2009. 4:12 AMef_jay says:
thats the o2 sensor on that model :P
Oct 11, 2008. 7:58 PMcararta says:
Am going to give it a try. Will let you know in a week or so how I did! Best info I have found, good clear instructions. Wish me luck!
Feb 21, 2009. 8:37 AMleighm says:
I recently purchased a 1990 Honda Civic hatchback with a blown headgasket and will be using this tutorial to help me through. I appreciate the posting and will follow up with comments on how it goes. I was just wondering if on page one you could provide a parts list of the bolts/gaskets/seals you replaced and recommend replacing while taking the head off, if any?
Feb 21, 2009. 5:26 PMleighm says:
Interestingly enough, Canada does not have any emissions regulations so I don't have any previous history of the vehicle. It's pretty much a shot in the dark but the previous owner had a mechanic shop look at the vehicle and came to the conclusion that it needed a new head gasket. He didn't want to go through the trouble so I took on the project. I started working on the car today and have the intake manifold left to remove. I should be able to take a look at the block tomorrow and will take some pictures. I will also check out eBay and see if I can find a manual as I know they are a great help!
Sep 21, 2008. 6:20 PMp.cassady says:
your cylinders still have the cross hatching in them so ur good.
Aug 24, 2008. 3:27 PMthearchitect says:
Wow, great job there! I can't believe that one-year was enough for a gasket to fail like that! If only you could reclaim your lost hours on that from the mechanic who mis-installed at the first place. Good job, anyway. I miss digging my '85 civic. I gave it away to Googwill before I left the States for good. Cheers, K.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Fort Mental
