3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Head Gasket Replacement on '91 Honda Civic
Step 8Install new Gasket and Reassemble
1) Before putting on the new gasket, you'll have to remove those old pieces of gasket that have welded themselves to the flange surfaces. I used a new razor blade and carefully scraped away the material without scratching or scraping away the soft aluminum (easy). See video.
2) Put the new gasket on the bottom of the valve assembly. Unless your gasket specifically requires it, do not use any gasket sealer.
3) Place it carefully, and slowly, back onto the head taking great pains to not ding the gasket!
4) Inspect and clean your bolts....remove corrosion and rust. If they show cracks or strips, replace them!
5) A dab of oil is all that's needed to lubricate the threads before inserting them back into the valve assembly.
6) Tighten the bolts as specified in the manual....It's three step process: Finger tight, torqued in a crossed-x pattern to 22ft-lbs, and then again to 49 ft-lbs. Follow the diagram! (easy). See video.
7) Carefully reassemble in reverse order...(pay attention, and don't end up with loose parts!)
IMPORTANT NOTE:As for re-installing the timing belt, loosen the tensioning pulley by accessing the bolt through the lower timing belt cover access port. I did not know that I could do this, and as a result, ripped the timing belt and spent an additional half-day having to uncouple the front engine mount, loosening the alternator, pulling off the belts, pulling off the crankcase pulley, removing the lower timing belt cover, and so on and so on. What a pain!
8) After reassembly, I successfully re-started the car with no problems. However, you may, as I did, end up with a "Check Engine" light. There are a few instructables showing you how to diagnose engine codes. In my case, I had two codes of which one went away after re-setting by completely disconnecting the battery. The other codes was the result of a missed connection; I reconnected the harness and the red LED code went away (Thanks Instructables!)
Good Luck! I hope you learned from my experience!
5 comments
Oct 11, 2008. 7:58 PMcararta says:
Am going to give it a try. Will let you know in a week or so how I did! Best info I have found, good clear instructions. Wish me luck!
Feb 21, 2009. 8:37 AMleighm says:
I recently purchased a 1990 Honda Civic hatchback with a blown headgasket and will be using this tutorial to help me through. I appreciate the posting and will follow up with comments on how it goes. I was just wondering if on page one you could provide a parts list of the bolts/gaskets/seals you replaced and recommend replacing while taking the head off, if any?
Feb 21, 2009. 5:26 PMleighm says:
Interestingly enough, Canada does not have any emissions regulations so I don't have any previous history of the vehicle. It's pretty much a shot in the dark but the previous owner had a mechanic shop look at the vehicle and came to the conclusion that it needed a new head gasket. He didn't want to go through the trouble so I took on the project. I started working on the car today and have the intake manifold left to remove. I should be able to take a look at the block tomorrow and will take some pictures. I will also check out eBay and see if I can find a manual as I know they are a great help!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Fort Mental
