introAutomotive Headlight Projector Mod V1.2
Modding your projector on the cheap!
With the simple use of a 12V Automotive headlight and a power supply.
The OEM replacement bulb for my projector cost ~$300! More than what I paid for the projector it self. And my power supply that powered the original bulb was almost toast. Using this guide you can use an automotive head light bulb for about $15 dollars.
If you like this mod please Digg It!
Please note: This project has been added to please check out my Halogen WORK LIGHT Projector Mod
WARNING : This mod involves modification of a power supply, projector, and a high power bulb if you are not comfortable with moding on this level, DO NOT attempt this mod. The writer is not responsible for any injuries resulting from these instructions.
Remove these ads by
Signing Up.
step 1Gathering parts and supplies
For this mod you will need the head light ($7), power supply (old
PC supplies work well $5), and some good gauge wire ($2), thin bare
craft wire ($1), pliers and other tools. And oh yeah, one projector
with a burned out bulb (E-bay).
To Download the PDF or View All Steps, Become a Pro Member » |
On a more personal note I had made the mistake of trying to use an external power source in conjunction with the ballast without properly bridging them..luckily the projector had a 4A fuse in it. Of course I didn't find this out until AFTER I had tossed it in the trash and pulled it out again a few days later. I'm using a Sylvania 9007XV with both filaments and it hardly provides enough light to see the picture. I looked up the spec sheet:
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/HighPerformance/Xtravision/ProductLine/
Its trying to pull 12-13 amps, so when I get home today I'll be removing the low-beam lead. Hopefully this will improve the brightness for me! :)
Thanks for this project, and thanks to lumenlabs as well!
Next attempt will involve over-volting! yay! 19.8v laptop PSU aught to do the trick...
I am using an acer pd100 projector, but it does not power up unless there is a working bulb in it, now I have to trick it into thinking that there is a bulb in by using a resistor but i have no clue wich one to use.
I have looked up the bulb but cant seem to find how much power it uses, that is if its 12 volt or 220 (I am in europe)
the bulb:
http://www.oztion.com.au/buy/auction.aspx?itemid=9673891
any ideas as to what strength resistor I should use?
Should try something like this . It would last years.
quang cao online | quang cao
What you guys should look for is a HID Xenon Kit, that consists of a Xenon gas filled lamp (works as the OEM halogen one) and a Ballast. I'd go with the 35W since it's the most commonly available, but maybe a 24W kit is a "safer choice".
Color temperature should be something around 4.300K (warmer white-yellowish) to 6.000K (colder white-bluish), I'd personally stay with the 5.000K option that mostly resembles the original projector lamp.
Now just work on a different power supply that delivers some 6A @ 12V then you're set, a 35W 5000K HID Xenon lamp delivers something around 2800lumens, should be plenty of light and also much more safer because it won't heat as much.
Congrats for the instructable btw, I would have never thought of that.. =D
Be very carefull when poking around HID lamps, the voltages can be lethal. Its also certainly enough to fry most multimeters....
As for tricking the projector into thinking the bulb is working - yeah, there is a lamp sensor on most projectors, but the means of bypassing it will vary somewhat from one make / model to the next. Some simply need shorting together or a voltage applied, to trick the projector. YMMV. :)
It feels like this mod is 90% complete, and leaves the experimenter hanging with a few steps to complete.
ANY info would be great. Even successful mods on any other retail projectors. Inquiring minds want to know!
Something about the power supply worries me quite a bit.
I don't want to burn my house down by drawing 20A with an ATX power supply. I know Ohm's law shows that that's not much wattage at 12v.... but I want to be absolutely sure I'm not running much risk running a 400W supply at 12v to power this thing. The math of that scares me: 30 A current to the bulb. That might actually blow it too.
I dunno if my understanding of lightbulbs and current are right....
... I guess I am probably just obsessing. I managed to dig up an entire post on just lightbulbs. The last few posts were what I needed to read... but it didn't entirely clear things up.
http://www.advancedphysics.org/forum/archive/index.php/t-2723.html
Anyways - I just want to know from somebody whether I'm running the risk of drawing too much current on my house circuit.
