With the simple use of a 12V Automotive headlight and a power supply.
The OEM replacement bulb for my projector cost ~$300! More than what I paid for the projector it self. And my power supply that powered the original bulb was almost toast. Using this guide you can use an automotive head light bulb for about $15 dollars.
If you like this mod please Digg It!
Please note: This project has been added to please check out my Halogen WORK LIGHT Projector Mod
WARNING: This mod involves modification of a power supply, projector, and a high power bulb if you are not comfortable with moding on this level, DO NOT attempt this mod. The writer is not responsible for any injuries resulting from these instructions.
Remove these ads by
Signing UpStep 1Gathering parts and supplies
£36.49 + postage from here is the cheapest I found.
http://cgi.ebay.co.uk/HD-LED-Projector-EXTRA-REPLACEMENT-SPARE-BULB-LAMP-/150591650632?pt=LH_DefaultDomain_0&hash=item230ff63b48
Copy and past that link and you can see for yourself.
I was going to do the same thing, ie buy a used projector with no bulb and make my own, But I decided to buy one of the cheap Abis projectors off ebay.
I was very supprised how good these cheap projectors are.
But be very carefull. I purchased the Abis HDpro for £200 and it has two hdmi inputs, component, composite input, vga and tv tuner input. It handles 720p fine and 1080p with compression 4.3 to 16.9 aspec ratio in all formats. Some other makes don't have all these features. It saved me a lot of hassle trying to make one work the way you have.
But if you are trying leds I would look at the cheap led projector bulbs off ebay.
Lamp Life: UP TO 50,000 hours Total Watts: 96watts (32 High powered LEDs fused onto a cell Plate) and upto 2,500 lumens.
Something about the power supply worries me quite a bit.
I don't want to burn my house down by drawing 20A with an ATX power supply. I know Ohm's law shows that that's not much wattage at 12v.... but I want to be absolutely sure I'm not running much risk running a 400W supply at 12v to power this thing. The math of that scares me: 30 A current to the bulb. That might actually blow it too.
I dunno if my understanding of lightbulbs and current are right....
... I guess I am probably just obsessing. I managed to dig up an entire post on just lightbulbs. The last few posts were what I needed to read... but it didn't entirely clear things up.
http://www.advancedphysics.org/forum/archive/index.php/t-2723.html
Anyways - I just want to know from somebody whether I'm running the risk of drawing too much current on my house circuit.
On a more personal note I had made the mistake of trying to use an external power source in conjunction with the ballast without properly bridging them..luckily the projector had a 4A fuse in it. Of course I didn't find this out until AFTER I had tossed it in the trash and pulled it out again a few days later. I'm using a Sylvania 9007XV with both filaments and it hardly provides enough light to see the picture. I looked up the spec sheet:
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/HighPerformance/Xtravision/ProductLine/
Its trying to pull 12-13 amps, so when I get home today I'll be removing the low-beam lead. Hopefully this will improve the brightness for me! :)
Thanks for this project, and thanks to lumenlabs as well!
Next attempt will involve over-volting! yay! 19.8v laptop PSU aught to do the trick...
I am using an acer pd100 projector, but it does not power up unless there is a working bulb in it, now I have to trick it into thinking that there is a bulb in by using a resistor but i have no clue wich one to use.
I have looked up the bulb but cant seem to find how much power it uses, that is if its 12 volt or 220 (I am in europe)
the bulb:
http://www.oztion.com.au/buy/auction.aspx?itemid=9673891
any ideas as to what strength resistor I should use?
Should try something like this . It would last years.
