Head Mouse With MPU6050 and Arduino Micro
22,509
245
36
Published
Introduction: Head Mouse With MPU6050 and Arduino Micro
About: Hi, I'm Gabry295, and I like doing electronic things, even if at the moment I have only one Instructable :) I like robots and everything related, aaand videogames. Contact me for any question, I'll answer gl...
Hi everyone, here it is my new project, a mouse controlled with the movement of the head!
I decided to make this project once I received my accelerometer/gyroscope MPU6050 from IC Station, and I wanted to do something useful with this.
Then I found out that a "Head Mouse" already exists, made by Martin Millmore with another accelerometer/gyroscope: https://www.instructables.com/id/Head-Mouse-Game-controller-or-disability-aid/
Well here it is my version, made with an Arduino Micro and a MPU6050.
Thanks to IC Station http://www.icstation.com/ for the accelerometer/gyroscope they sent me, allowing me to create this project!
Step 1: Materials and Tools Needed
Materials needed:
- Arduino Micro;
- accelerometer/gyroscope MPU6050;
- a Compeed box (I found this comfortable as Martin Millmore said in his guide);
- an elastic band;
- micro USB cable to USB type B (like those used for Android smartphones);
- cables;
- a pcb board;
- glue, or better, Sugru.
Tools needed:
- a computer with the Arduino IDE installed;
- soldering station;
- mini drill.
Step 2: Building
1) Solder on the pcb board the pins like in the image: pin 2 of Arduino to pin SDA, pin 3 to SCL, pin 5V to PWR, pin GND to GND.
2) Make a hole with the dremel on the Compeed box so the micro USB cable can reach the Arduino Micro, and two straight holes for the elastic band.
3) glue the board to the box and add the elastic band.
Step 3: Code
Connect the board to your computer and load first the "Test" code to the Arduino to test if everything work fine. You'll probably need to change some values (everything is written in the code's comments) since I had to add a constant, beacuse values from the gyroscope are not "zero" when I'm not moving.
Use the Serial Monitor to check if you need to fix the "zero" of the gyroscope.
Once you found the right values you can load the program deleting the "Serial.print" part, that is equivalent to the standard code.
If you want the click function after a delay of time since the pointer has been in a 10x10 pixel zone load the code "with_click" to Arduino Micro.
Here there are the codes:
- standard code with only movement: https://www.dropbox.com/s/hnrhdtsoqzi8azr/Mouse_Gyro_ENG.ino?dl=0
- code to test the output: https://www.dropbox.com/s/t2f63ichd4g93n1/Mouse_Gyro_TEST_ENG.ino?dl=0
- code with movement and click after 2 seconds: https://www.dropbox.com/s/vdsg8jo1toebt4d/Mouse_Gyro_with_click_ENG.ino?dl=0
To use them you'll need the MPU6050 and I2C libraries:
MPU 6050: http://arduinomeetslinux.com/download/MPU6050.zip
I2C: http://arduinomeetslinux.com/download/I2Cdev.zip
In this site I found the libraries and the code from which I developed the programs of my project: http://arduinomeetslinux.com/content.php?p=5
Link to Martin Millmore's project with the LSM9DS0 instead of the MPU6050: https://www.instructables.com/id/Head-Mouse-Game-controller-or-disability-aid/
  • Clocks Contest
    Clocks Contest
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
Mouse_Gyro_ENG:33: error: 'Mouse' not found. Does your sketch include the line '#include <Mouse.h>'?
Mouse.move(vx, vy);
36 Comments
Always easier to start something new when someone walks you through it, thanks :)
I soldered the MPU6050 directly to the Arduino to save space (4cm of cables in all) and the "at rest" values for my module were -700 and 75.
Mounted it into my DIY headlamp (left ear has a LED brightness knob, maybe I'll put mouse sensitivity over the right?
WOW! I'm really happy it was helpful!
Your project is really interesting, the robot looks really good!
I'll take a better look when I have more time, I'm interesting in the algorithm that control the track of the robot
Hi, tried using this tutorial with my arduino pro micro and mpu6050, got the correct connections but unfortunately its not working, can you help me why please. Thanks.
Thanks for your awesome project. Great~~
No, you need an Arduino Micro or Leonardo, which have the "ATmega32u4" that interfaces directly with the PC and can be recognized as mouse or keyboard. See more by Googling "Arduino Leonardo" and "Arduino Micro" and check the description on the Arduino official sites.
ok.
i could implement other tasks, such as sustained click or secondary click, this with respect to programming?
I made a version which runs on every Arduino model using serial communication and python, but apparently I can't post the link here D:
Hi Gary, can u tell me what is "200" in your sketch? Thank u very much :)
The sensitivity.
As the sensor values can vary quite a lot this helps to keep the pointer calm.
If you increase it, the pointer becomes slower,
if you decrease it, the pointer becomes faster.
how can I include right click along with lest click option
Hi, I need to know what is the principle of working of the gyroscope, accelerometer and magneometer? please.
Very clever, but I don't think I'd like having to keep moving my head to move the cursor!
Now, an EYE tracking mouse, that would be ultra cool! (I bet you could do it with a webcam)
Yeah, an EYE tracking mouse would be super cool!!! Haven't a clue how to do it!
look at the EYETRACKER a open source project easily available and very cheap to make
using arduino nano can use for this project ? where to get libraries for mouse.h
