Time: 4-5 days (it rained so I let the stain and polyurethane dry extra long)
Cost: under $200 (before tax)
Supplies needed:
- 2 wood hollow interior doors (total width should be about 4" wider than bed).....$26.00 x 2 = $52.00
- 1 quart Pre Stain Conditioner.....$12.67
- 1 quart Stain (color of your choice).....$7.77
- 1 quart Polyurethane sealer....$10.77
- 3 cheap disposable synthetic paint brushes, one for each step of staining.....$7.97 x 1.5 = $11.96
- Lots of lint free cloths for staining (I used old torn up sheets).....n/a
- 4 tie plates.....$0.57 x 4 = $2.28
- 24 wood screws (4 x 3/4").....$0.98 x 1.2 = $1.18
- 2 heavy duty strap hangers w/screws (picture hangers).....$11.29 / 50 = $0.23
- Picture wire (about 6-1/2 feet).....($24.99 / 500) x 6.5 = $0.32
- 50lb monkey hook.....$2.97 / 4 = $0.74
- 2 sets of Ikea Dioder LED lights.....$29.99 x 2 = $59.98
TOTAL = $159.90
Remove these ads by
Signing UpStep 1: Stain Doors
I built this headboard for a queen size mattress which was only on a plain metal frame. The width is 60". I felt the headboard would look visually balanced with about 2" wider on each side. So the doors I bought were 32" wide for a headboard width of 64". This left enough space for the bedside tables to be close to the bed without bumping up against the headboard.
Stain both doors to desired color.
I followed the suggestions on the can and used a Pre Stain Conditioner.
I used Ebony colored stain, applied the stain, waited 15 minutes and wiped off all the excess stain and buffed the doors with soft cloths until no extra stain lifted off. After 12 hours I applied a second coat of stain, waited 15 minutes and wiped off all the excess stain and buffed the doors with soft cloths until no extra stain lifted off.
I stained both sides of both doors. Since I was using a dark stain the grain became very visible and so did any flaws in the doors. Staining both sides gives you the opportunity to pick the best side to be shown.
I also stained the edges since they will be exposed. Take care to wipe off any stain that drips to the underside.
Tip: Use cloths that are lint free. Old sheets worked best. I used a lot (I mean a lot!) of cloths because I put on a nice coat of stain like I was painting and after 15 minutes wiped most of it off.
I waited a full 12 hours before doing the next step.
Not Nice
Visit Our Store »
Go Pro Today »
