Headlamp Winter Hat
 by rbateman
Contest WinnerFeatured
Step 2: Cut your hat open
Cut your hat open along the bottom edge, that way we can stuff all of the internals inside of the hat. I would say that at the most you need to make a 3" incision, just barely enough to do some positioning in there.
Be sure to decide whether you want to have your LED bulb face out when the hat is rolled up, or if you'll want to wear it without rolling (like in the photo). Cut a small (I mean absolutely tiny) hole for your led to fit through. Poke the two legs of the LED through the fabric of the hat, then bend them to feed them through to the inside of the hat, where you can access them from the cut that you have made in the edge of the hat. The legs of the LED also provide an anchor for the bulb, helping to keep it in place.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
