Introduction: Headphone Stand
Picture of Headphone Stand
After destroying yet another expensive gaming headset, by rolling over the wires with the computer chair, I thought it was time to make a stand for the new ones.
Step 1: Materials Needed
Picture of Materials Needed
I found a template that I liked and printed it out in Microsoft office. I traced the outline onto my wood. I used scrap wood I had from an old project. I cut 2 pieces so that my stand would be chunky.
Wood
Hole saw cutter
Sanding wheel
Jig saw
Sander
Glue
Varnish and Stain
Router
Step 2: Cutting Out Your Shape
Picture of Cutting Out Your Shape
My wood was quite thick and I am not very accurate cutting out with a jigsaw, so I cut them about 2mm wider than the template. I glued the two pieces together and used my belt and disc sander to sand the two pieces to look like one, using the outline as a sanding guide.
Step 3: Cutting Out the Hole
Picture of Cutting Out the Hole
I marked out the center and added a hole to make it look better using a hole saw. I only drilled half way then turned my project over and completed the hole from the other side to prevent blowing out and damaging my project.
Step 4: Sanding the Hole
Picture of Sanding the Hole
I cleaned up the inside using a sanding wheel until the inside was smooth.
Step 5: Router the Edges
Picture of Router the Edges
And used a router to remove all the edges to give it a nicer look. And finally I sanded my project smooth and stain with dark Mahogany stain and gave it 3 coats of gloss varnish. Time for total project was 3 hours excluding drying times.
Marniacal (author)2017-07-21
This is both functional and beautiful!
AnitaH25 (author)Marniacal2017-07-21
Thank you
About This Instructable
1,481views
29favorites
Bio: I enjoy repurposing and restoring old furniture and making woodwork projects that are not seen every day. I make most of my projects using wood ... More »
More by AnitaH25:DIY Headboard Bench Epoxy Resin Steampunk Door Knobs How to Make a Santa Stop Here Sign
Add instructable to:
