loading
Step 2: Carefully Slice It Open
I must emphasize carefully, for it is small and knives tend to slip. My headphone plug was rubber and was fairly easy to cut.
I cut it along the outside seam of the molding. I attempted to avoid cutting the strain relief (the flexible area where most wires break) but the wire appeared to be fused to it and I had to cut that part open as well.
The end was encased in some sort of plastic, I assume similar to hot glue. We will deal with that later.
I chopped off the end about an inch from the source of the problem.
<p>If the headphone plug is broken off in the jack consider this tool, the GripStick that is designed to remove broken plugs from devices... now on Kickstarter</p><p>https://www.kickstarter.com/projects/nightek/gripstick-the-broken-headphone-plug-removal-tool</p>
<p>This was successfully funded, and it is now for sale here:</p><p><a href="http://nightek.com/" rel="nofollow">http://nightek.com/</a></p><p><br><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/Ii5OKvtNxe4" width="500"></iframe></p>
thanks for the instructions reall helped get me started.
Very good instructions. Helped me fix my headphones. Thanks!
Wow, I must say that this is probably the cleanest and most professional headphone repair job I have ever seen. Only thing that could make it better would be to have all the heat shrink be black, but that is just being too nit-picky. Great job!
I have simply cut off all of the plastic plug cover and soldered the wires to it. Then I covered the plug and wires with hot glue to simulate a plastic plug cover. It looks a little homemade, but works well.
Repaired tons of headphone, but your tutorial is amazing.. very clearly. Looking around for those ultra short jack to make apple-style headphones! ;D
=] thank you. The cable I fixed was from radioshack, an overpriced $8 cable... But it was a hard to find short in line volume control for my in ear headphones. <br/>
somehow remember me to my guitar cable 'ible , good job and great pictures!
About This Instructable
121,932views
42favorites
License:
More by awdark:Headphone plug repair
Add instructable to:
