Introduction: Heart Pendant
In this instructable you can read how to make a heart pendant from a coin.
Material
- Coin
- Paper
- Cardboard
- Colored paper
- sponge
- Old t-shirt
Tools
- Scissor
- Hacksaw, dremel or grinder
- Drill
- (Super)glue
- Ruler
- Exacto knife
- Different grades of sandpaper
- Clamp
- Metal polish
- Cloth
- Hammer
- Center punch
- Pliers
Step 1: Choose a Coin
For this project I used a Belgium 5 Franc coin.
The coin is made of aluminum bronze.
Aluminum bronze consists of 92% copper, 6% aluminum and 2% nickel.
Step 2: Shape the Coin
Shape the coin in the form of a heart.
- Cut a heart out of paper in the size of the coin with a scissor
- Glue the heart with (super)glue on the coin
- Grind or cut the remaining material away with a hacksaw, dremel or cutting tool
- Remove the paper heart of the coin
If you find the pattern of the coin well, then you can proceed to the next step.
When you want a blank canvas or a mirror finish then continue with this step.
- Grind the pattern off the coin with a dremel, grinder or sandpaper
Step 3: Drill a Hole
Drill a hole in the coin.
- Find a place where you want to drill the hole
- Mark the center of the hole with a center punch and a hammer
- Clamp the coin securely on top of a piece of scrap wood
- Drill a hole at the site of the markeering
- Use the smallest drill bit you have (my smallest drill bit was 3mm)
- Sand the burrs off of the coin
Step 4: Sanding and Polishing
Sanding
- First use a dremel or grinder to sand the greatest scratches away
- Then use fine sandpaper to sand the little scratches off (I used 400 grade sandpaper)
- The finer the grade, the better the result
- For the very small scratches, I use a whetstone (a higher grade sandpaper is better)
Polishing
- First use a dremel with polishing material
- Let the brush of the dremel go through the polishing material at a low level
- Increase the level and polish the coin
- Remove the polish of the coin with a cloth
- Polish the coin now for the last time with a liquid polish
- Put a little polish on a cloth and rub the coin
- Rub the coin until you see a mirror finish
- Remove the excess material with a clean cloth from the coin
Step 5: Place a Ring Through the Hole of the Pendant
- Open the ring with pliers
- Place the ring in the hole of the pendant
- Close the ring with pliers
- Place the pendant to a necklace
Your hanger is finished.
Step 6: Make a Box
Cut out the following pieces of cardboard
Lid
- 1 time a piece of 32 x 32 mm
- 4 times a piece of 34 x 0.75 mm
Box
- 1 time a piece of 28 x 28 mm
- 4 times a piece of 30 x 15 mm
- Glue everything down in a windmill pattern
- Glue colored paper on the outside of the box, the outside of the lid and the inside of the lid
- Cut out 3 pieces of sponge to fit the inside of the box
- Cover the sponge with an old t-shirt and place the pieces in the box
Your gift is ready.
Happy Valentine's Day.
Runner Up in the
Makerlympics Contest
First Prize in the
Valentine's Day Contest
