Hearty Beef Stew
 by Phil B
Featured
We had a recipe for beef stew, but it was rather ordinary. I thought I could improve on it. I have made it for a number of people and all of them like it very much.
Step 1: First ingredients
Prepare and place into a 2.5 quart crock pot the following ingredients--
  • 2 pounds of stew meat (beef) cut into small cubes
  • 1/2 pound of beef stick summer sausage sliced and quartered
  • 2 medium onions cut into eighths
  • 4 medium carrots in thick slices
  • 2 stalks of celery sliced diagonally
  • 1 can of kernel corn (10 to 12 ounces)
  • 1/3 cup of quick-cooking tapioca
  • 3 or 4 medium potatoes quartered and sliced
I added part of each of these in a continuous rotation so they are already mixed as I place them into the crock pot. Press these down into the crock pot to make room for the lid, if necessary. Normally I peel the potatoes, but decided to leave the skin on this time. The skins are supposed to contain good nutrients.
Remember that this is stew, and you can use whatever you have. Add something extra that is not in the recipe, if you like. If you do not have some ingredient or find it difficult to get, do not worry. Stew ingredients can be flexible.
coolbeansbaby68 says: Aug 29, 2012. 9:59 AM
Yummy comfort food !
karossii says: Jun 4, 2011. 9:05 PM
Never heard of putting tapioca in a stew before; what is its purpose... as a thickener of the sauce? Does it affect flavor much? Is there a specific type of tapioca you use?
Phil B (author) in reply to karossiiJun 4, 2011. 9:40 PM
The tapioca was part of the original recipe, not one of my alterations. I suspect it serves as a thickener. I did not notice any taste from it. There are a number of more powerful and quite different flavors so that the tapioca would not be noticed. We had Kraft Minute Tapioca in the cupboard and that is what I used. Thank you for your comment.
kill-a-watt in reply to Phil BJun 4, 2011. 9:56 PM
I would agree about the thicker part. In fact, I have some powdered tapioca I got from an international grocery for my sister. She likes to use it to thicken pie filling made from scratch. This saves her the effort of grinding the tapioca pearls down into powder herself.
I would assume you use less if you had powder to achieve the same mouth-feel. Some experimentation is in order, I think.
Phil B (author) in reply to kill-a-wattJun 5, 2011. 3:14 AM
The Kraft tapioca product I mentioned consists of granules no more than 1/16 of an inch in diameter. I do not cook a lot, but am more accustomed to hearing about corn starch as a thickener. It is probably a good thing to have a thickener so the liquids are like gravy when finished, and not so thin they run all over. I would usually eat this stew on a dinner plate. This time I decided to eat it in a soup bowl with a spoon. It could go either way, depending on your preferences.
kill-a-watt in reply to Phil BJun 6, 2011. 12:52 PM
OK, never mind what I said about using less of the powder. I didn't understand that the tapioca pearls cook down to nothing in the slow cooker.
I made the recipe with some substitutions for what I had on hand:
Meatballs instead of beef
omit potatoes (unfortunately this is the wrong type of carb for me)
Add more celery and carrots
use1/2 cup of frozen succotash instead of the canned corn (quite a bit less corn in the mix)
No summer sausage (next time for sure)
4oz of sherry instead of the bourbon
I had both the tapioca pearls and powder on hand and tried the pearls. They had dissolved within two hours.  The stew turned out really well. Google says that tapioca is a better thicker to use when freezing, and since I'm all about "plan-overs" (deliberately planning on making extra, and freezing the leftovers) this should work out well.
Phil B (author) in reply to kill-a-wattJun 6, 2011. 1:04 PM
Thank you for trying it and for the report back. You made enough changes to what I did that it really is your own.
kill-a-watt in reply to Phil BJun 8, 2011. 9:16 AM
You are too kind. I go by the "Ann Hodgman's rule" of giving recipe credit. To claim a recipe as your own, you need to make three major changes. You can't just add an extra half a teaspoon of salt and call that a change, you need to add an extra half cup!
So under that rule, I could:
Swap the stew beef for ground rabbit meatballs (rabbit, the other other white meat!)
Add a totally new vegetable, like rutabaga.
And then change the whiskey to sherry and call it a totally new recipe.
Also, I have a recipe for beef satays that uses whiskey to tenderize. I would suggest if the beef you use isn't totally tender after all of that slow cooking, then you could marinate the beef overnight in the whiskey first, and then add everything to the crockpot when you start to cook.
The first batch never made it to the freezer, because I ate it all for lunch and dinner (doing roofing work makes you pretty hungry), so I'm trying again. The only appropriate spirit in the house is my favorite rye, and I'm not  willing to try that so today I used a bottle of stout. I also switched up to hamburger patties (easier to pre-brown) and threw in a small handful of frozen shoestring french-fries.
Burger and Fries Stew anyone?
Phil B (author) in reply to kill-a-wattJun 8, 2011. 9:50 AM
I like the three ingredient rule. I also have a great respect for roofers. To me it seems roofers are working in unfavorable weather conditions most days of the year.
kill-a-watt in reply to Phil BJun 8, 2011. 10:23 AM
just some roofing on my own house. If I was a roofer every month of the year I would not have to worry about carbs!
karossii in reply to Phil BJun 5, 2011. 10:45 AM
I do usually add a teaspoon or two of cornstarch (pre-dissolved in an equal amount of cold water) to a stew when I start it... never tried (or heard of anyone else using) tapioca instead. Will have to give it a go!
NaturalCrafter says: Jun 6, 2011. 12:11 AM
I believe the bourbon helps to tenderize the meat. It is sometimes good to take the meat and let it sit in that or wine the night before. Some people add the onions fresh or lightly browned. I have never used tapioca for a thickener other than adding it to a Hawaiian salad. Stew is always great and I like your combination. (Making note card for my box) Thanks for sharing.
Phil B (author) in reply to NaturalCrafterJun 6, 2011. 3:32 AM
Yesterday someone mentioned the bourbon as a possible tenderizing agent. The original recipe mentioned that the meat may be marinated before cooking. I did trim some very hard fat from the stew meat, also some tough sinew. After 7 hours of slow cooking, it was very tender; so I do not know why marinating would be necessary. Again, thank you for looking.
NaturalCrafter says: Jun 6, 2011. 12:13 AM
Hungarian goulash is great with beer in it also. A creative cook made that up for dinner for us once...lol
Phil B (author) in reply to NaturalCrafterJun 6, 2011. 3:29 AM
I had the thought that adding sausage makes this stew a little like Hungarian goulash. What fascinates me is that a rather bland recipe for beef stew became something much more exciting by adding only a couple of ingredients. Are you the aforementioned creative cook? ;-) Thank you for commenting and for copying the recipe.
rimar2000 says: Jun 4, 2011. 5:49 PM
Phil B posting cooking recipes! The universe is changing...
Anyway, being yours, maybe I must try it.
Phil B (author) in reply to rimar2000Jun 4, 2011. 6:18 PM
If you do try it, do not worry about the bourbon whiskey. The alcohol boils away during the cooking. I do not know if you have something like summer sausage in Argentina or not. It is often sliced and served on crackers. It has a taste of black pepper and garlic. This stew is much more interesting than ordinary beef stew. I made it for a group of church ladies once. They liked it very much. Thanks, Osvaldo.
rimar2000 in reply to Phil BJun 5, 2011. 5:34 AM
Thanks, Phil. I don't know that summer sausages. There are "chorizo colorado" (red sausage) with [paprika - cayenne] but surely they are different. Also "salamines" (salami), maybe they are more similar.
Anyway, my cooking skills go a bit over fried eggs...
Phil B (author) in reply to rimar2000Jun 5, 2011. 7:06 AM
Osvaldo,
Summer sausage is probably more similar to salami than to chorizo. You could use any sausage you like to add a little flavor. The summer sausage is pre-cooked and ready to eat cold. But, the crock pot I used for cooking cooked the raw stew meat. It would also cook raw sausage so that it is safe to eat. If you can fry an egg, you can make this stew.
kill-a-watt says: Jun 4, 2011. 7:24 PM
Looks good. The bourbon is your secret ingredient. I'll have to try that.
My secret ingredient is to use condensed tomato soup. I don't know what it is, but it makes a very tasty stew.
The original recipe was from a book called "Beat This!". There is an adaptation of the recipe here at this URL by another author.  She uses red wine, but I usually add 12 oz of dark beer (original recipe called for "beer", wine or water, and I just have to assume that the original author used something awful like Bud lite).
I usually cook it in my cast iron dutch oven, but I take the lid off and add in one or two of those "biscuits in a tube" during the last 12 minutes or so, leaving the top off so they can cook and brown in the oven.
Phil B (author) in reply to kill-a-wattJun 4, 2011. 7:55 PM
I know some people who like Dutch oven cooking very much. I understand about the biscuits. I do not have a Dutch over kettle and have not tried that.
The bourbon is one of the "secrets." I believe the summer sausage is another, as well as the garlic powder.
We frequently go to a Mongolian BBQ. I like to be sure to add the red cooking wine sauce.
Thank you for looking and for commenting.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
