Heat Gun Rubber Stamps and ATCs
4,116
169
8
Published
Introduction: Heat Gun Rubber Stamps and ATCs
About: Hi everyone! I'm a hardcore DIY'er, I've published 11 DIY books, just produced my own TV show called Make Your Mark for PBS/APT, I make YouTube videos every week and I'm buried under a mountain of craft sup...
Make rubber stamps with kids sticky foam and a heat gun and use them for texture in your art journals or for artist trading cards.
Step 1: Watch the DIY Video Here!
Step 2: You'll Need
Wood blocks
Sticky back craft foam
Cardboard
Americana Multi-Surface Satin Paints
Stamp pad
White glue
Hot glue gun
Items with texture (I used a beaded appliqué)
Heat gun
Clip art
Paintbrushes
Step 3: Create a Textured Design
Cut and stick 3 layers of sticky back foam to a wood block
Draw a design on cardboard
Trace over the design with hot glue
Heat your sticky foam wood block until the edges begin to curl
Firmly press the heated foam block onto the raised hot glue design to make your stamp
Step 4: Add Ink or Paint
Spread a thick layer of paint on a flat surface
"Ink" your stamp with the paint and press onto a card
You can also use an ink pad with the stamps
Cut out clip art images and glue them to your stamped cards
Step 5: Embellish
Paint around the edges with metallic paint and by rubbing the edges over the ink pad
Fill in the clip art images with more color
Add more stamping
Decoupage small pieces of paper, book pages and quotes
Be creative and experiment!
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    8 Comments
    Simply love it. Easy, and unlimited possibilities!
    The video is more wahoo effect, i shall say
    I always learn something new, Thank you
    Totally inspiring idea! Thank you.
    Thanks GillyJames......I've made quite a few and they've lasted after tons of use. Not sure if you have embossing folders, but they work well for texture, too.
    Thanks seamster! Still blown away by your woodworking skills!
    That's a great technique!
    I love sticky-back craft foam. That stuff is surprisingly useful for so many things. Here's one more to add to the list. Nice!
