Introduction: Chicken Coop Drinking Water De-Icer
I keep chickens in an outdoor coop and run in Western New York. In winter, we get temperatures as low as 19º F. in the winter. That leads to the chickens' water freezing. I had a Bucket De-Icer that I had submerged, but the water kept turning rusty, and the element got all corroded. Also, the top of the bucket needed to stay open for the chord, and I prefer to keep the bucket closed so it doesn't get debris inside.
My solution was to make a mini water heater with drinking nipples for the chickens.
Step 1: Find Container... Drill a Hole.
I had a 5 Gallon Plastic Hedpack from another project, so I used that. The fact that it is rectangular makes it easier to butt up against the side without it moving around too much. I drilled a 1" hole to insert the Submersible Stainless Steel Heating Element. The threading was 1" NPT, so I had to widen the hole little by little with the dremel, until I could get threads to catch the plastic. I made the mistake (on my first attempt) of drilling the hole too close to a ridge on the container, and the washer wouldn't sit flat, so it would not stay watertight. The second hole shown was just a test hole, since that container was garbage... I ended up using a second container, and it worked fine once I drilled the hole in a flat spot. I just used some teflon plumbers tape on the threads and there are no leaks.
If I were to make another one of these, I would try to install a Bulkhead Fitting so that in the summer, I could remove the heat element and put in a Plug. I feel like the threads on the probe would go in and out easier. The heating element came with a silicon sealing washer which is flexible and waterproof. So far, it's holding well.
Step 2: Drinking Taps
My chickens drink from Poultry Water Nipples, so I put four of them at the bottom of the container. These are pretty much self tapping into plastic. I had to bevel the opening a little bit for them to get started, because of how thick the container is. **Don't over-torque the nipple, or it will strip the threading on the bucket. I didn't use teflon tape, and they are water tight. There is a soft washer on them. It doesn't need to be crushed.
Step 3: Connect Power Supply
In the future, I'm going to add a Temperature Sensor and regulate on/off based on need. For now, since the water had turned to solid ice, I just connected it to a Power Supply i had. I spliced it to a longer paired wire and just connected the leads. I checked everything with a multimeter, and it's all holding up.
I used a 400mA supply, because I didn't want to get the element too hot. I'm not looking to boil the water, just keep it from freezing. In the spring, when I'm not fighting against freezing temperatures, I plan to experiment with different power supplies to determine how quickly the water heats up with different amperages. With an temp sensor and an automatic on/off switch, it should matter that much. i.e. if water temp < 5ºC, then turn on. if water temp > 10ºC, then turn off.
The next step will be to connect this (and a few other functions) to a Raspberry Pi and an Automation HAT, all connected to a Solar charged 12V battery.
