3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Heatgun Desoldering
Step 2Heat up area using heatgun.
Now you will heat up the area with the heatgun. I would suggest using something nonflammable to put the item on and place it at a comfortable angle to work with. I used a old case side to protect the bench. You will also want to make sure there is nothing that could melt or burn in the area around it.
Here I am going to heat the area around the yellow SMT parts in the top left corner.
After heating the area. Watch the solder to turn shiny to show that its flowing, You can then remove the parts using tweezers or needle nose pliers. Then place in a safe place to cool off.
Be careful especially with the smaller parts or the parts that might be heat sensitive. The air from the heatgun can blow small parts around. You also don't want to burnout the parts you are trying to save.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mage2
Just a geek, if you need to know more. ask.
