A friend goes to Hawaii every year and brings back a sack or two of macadamia nuts in the shell. When he tries to crack the nuts with a hammer, the force required is so great that he crushes the meat of the nut, too, when the shell finally yields. He needed a special nutcracker. Here you see it in use.
Remove these ads by
Signing UpStep 1Make teeth in the jaws
When machining needs to be done on a smaller piece that would be difficult to hold I like to do the machining first and then cut the piece away from the larger bar stock. Use a thin cutting wheel to make teeth on the jaws. It does not matter that the jaws resemble a square wave rather than saw teeth. One of the jaws will be 1 3/4 inches long. When the teeth have been cut for it, cut it away from the bar stock.
Cut identical teeth for a second jaw and make them over a length of 1 3/4 inches, also. These teeth are enough to grasp the shell of a nut and hold it while it is being cracked.
Please feel free to come by and pick up some nuts whenever you make it back again. It'd be nice to make your acquaintance. Until later, be well and thanks for the Blackhawk lead. Aloha Jamil
A pipe wrench would make an interesting start for a nut cracker. An idea that comes to mind would be to separate the movable jaw from the wrench. Mount it facing upward so it is fixed to a 2 x 4. Turn the rest of the wrench over and bring the jaws close enough to each other. Fashion an axle to the big part of the pipe wrench near the jaw. Use the handle like a lever to open the space between the jaws and then pull the handle down to put pressure on the nut to crack it.
I looked at a map to see where your location is. We did a driving tour around the Island of Hawaii and went through your city, although I do not specifically remember it now. You must be a little up the coast from the low town where much of the town, including some school children were washed out to sea during a tsunami back in the 1930s (I think). We stopped and read several historical markers about it.
As I mentioned, this was designed to crack macadamia nuts. Their shell is about 3 to 4 millimeters thick and very hard. Anything less than a nutcracker of this caliber is probably inadequate. Yet, it can be used for a variety of other nuts, even though they are not nearly as hard as macadamia nuts.
I use the "Atlas clamp" or "dog clamp" (http://www.google.com.ar/images?q=%22pinza+perro%22&oe=utf-8&rls=org.mozilla:es-AR:official&client=firefox-a&um=1&ie=UTF-8&source=univ&ei=a8GoTL-eEYLGlQek_sDADA&sa=X&oi=image_result_group&ct=title&resnum=1&ved=0CCYQsAQwAA&biw=1139&bih=506) as nutcracker, but yours is better.
Have you tried using a stick of dynamite? But surely your homemade nutcraker is more effective!
