Helice: Spiral Organizer
Published
Introduction: Helice: Spiral Organizer
Spiral organizer composed of the triangular based shelves that simultaneously open and close for convenient viewing and storage of items
Step 1: Step 1: Procure Materials
You will need:
1 Sheet 3mm Acrylic
1 30-cm steel tube with 12.7 mm diameter
1 Sheet of MDF
Tamiya Cement
Super glue
Needed for this project:
Lasercutter
Step 2: Step 2: Lasercut This File for the Shelf
https://drive.google.com/file/d/1UPpwhZYuGc_oVBXup-6ueT0MHKalmZMI/view?usp=sharing
Lasercutting details:
1. Open the file in Adobe
2. Print
-select the Lasercutter as your printer
3. Lasercutting
-properly calibrate the z-axis of the laser cutter using the calibration tool
-duplicate the design twice in order to laser cut a total of three copies
-check the settings and change the cutting settings to something compatible for 3mm acrylic
-make sure pointer is on the right place in such a way that the whole print fits in one sheet
-print away
Step 3: Step 3: Assemble One Shelf
-Place the wider rectangular pieces and fit them on each side of the triangular base piece
-place the shorter and narrower piece on the short side of the triangular base piece
-reinforce with Tamiya cement
-superglue the additional hole piece 1.5 cm from the top part of the shelf walls (wider rectangular pieces)
-repeat for second shelf
-for the third shelf super glue the hole piece on the top most part of the shelf walls
Step 4: Step 4: Final Assembly
-lasercut an mdf base with dimensions 14cm by 8 cm with a 12.7mm diameter hole
-fit the tube on the hole of the base
-add the shelves in. start with the ones with the lower second hole piece. then for the top most shelf use the one with the hole piece on the top most part of the shelf
-make sure that one wall is inside the shelf below and one outside in order for the mechanism to work
    • Make it Move Contest
    • Flowers Challenge
      Flowers Challenge
