3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
This instructable is not complete and I am not currently working on it.Heliostat experiment and finding true north with equatorial mount.
If a mirror revolves on equatorial mount at 7.5 degrees per hour will it cast the light of the sun in the same direction all day?
This is a very low tech experiment so that I can better understand heliostats.
I do this experiment because of my lack of understanding of heliostats, because of an answer on wikipedia i did not understand and because of a big arguement about heliostats on instructables last year.
Also, there is very little information on the net about how mechanically powered heliostats work.
They were common use over a hundred years ago.
It is snowing today march 9 (usually they have a flower count here in early February!) so this gives me time to put this instructable on as requested.
Step 1Materials and tools
Materials and tools
Parts of the device The device was made from a
hairbrush.
a tightner for a a clothesline
a bolt
some screws
a crocodile clip
a piece of tie wire
and a protractor picture that I downloaded from the internet
You need a bench drill to drill holes straight into wood at right angles to the surface.
A hand drill is probably not accurate enough.
Screwdriver is also needed.
20 comments
Jul 23, 2009. 6:38 PMcdousley says:
Becase of an eleptical orbit each day varies in lenghth
Mar 19, 2009. 12:21 PMdavid williams says:
We've discussed this topic ad nauseam. In general, a mirror rotating once every 48 hours will NOT reflect sunlight in a constant direction. There are exceptional situations in which it will work, but only on certain dates of the year. When the sun comes out in BC, try it. (You should come to Ontario where we're enjoying beautiful sunny weather!) But don't spend (waste) much money on the experiment. Use two mirrors. Make one of them rotate about a polar axis once every 24 hours and align it so it reflects light toward one of the celestial poles. Put the other (stationary) mirror so it intercepts the light reflected from the rotating mirror and sends it in whatever direction you want. This simple arrangement will reflect sunlight in a constant direction for several days, but will need readjustment every few days so as to compensate for the sun's seasonal movements in the sky. David
Mar 20, 2009. 11:10 AMdavid williams says:
Try a simple "thought experiment". Suppose you want to reflect sunlight in the direction of the celestial north pole, i.e. at the pole star. How are you going to make a mirror that rotates once every 48 hours about a polar axis do that? Answer: It won't. It could work if the mirror rotates once every 24 hours, following the sun's motion in the sky, but not 48.For most other target directions, the 48-hour rotation idea also will not work. I did explain this at great length to Osvaldo ("Rimar 2000") some months ago in private e-mails in his native Spanish. However, verbal descriptions and two-dimensional diagrams were inadequate. The situation is basically three-dimensional, and only a three-dimensional model (or imagination in three dimensions) can show how it works. If the above thought experiment doesn't convince you, then you'll just have to build the machine, wait for sunny weather, and see what it does. You asked for anyone who has done relevant experiments to tell you what they showed, since your weather isn't suitable at present. I suspect that I am the only person here who has actually done relevant experiments (years ago), and I know that they showed that the 48-hour idea does not usually work. (It does work only if the latitudes of the sun and target are equal and opposite. Since the sun's latitude varies in the range +/- 23.5 degrees during the year, the machine can work only if the target's latitude is also in that range, and only on the two dates of the year when the sun's latitude has the required value.) However, when I told you that it doesn't work, you took offence. So why did you ask? Since I know that the thing won't work, I also know that any money you spend on it will be wasted. However, if you want toi experiment with it, you have a perfect right to do so. My friendly advice is not to waste much money, but it's up to you. The two-mirror idea is simple and does work. I have a heliostat that works that way. But you don't seem to like it. I have no idea why. I know you have seen pictures of heliostats made by a man named Silbermann in the 1830s. They have single mirrors and are driven by clockwork. (They were actually used by artists, painters and sculptors, who needed unmoving beams of sunlight to illuminate their subjects.) They are beautiful and ingenious machines. But their mirrors do not rotate once every 48 hours. They have complex mechanisms to move them appropriately. I don't think I am the one who should be booted out for not "being nice". Try looking at your own behaviour. David
Mar 28, 2009. 1:56 PMdavid williams says:
I've been doing some more calculations on this and have realized that, even under the unusual conditions in which the mirror rotates at a speed of 7.5 degrees per hour, it still returns to its original orientation every 24 hours, not 48! (This is neglecting seasonal movements.) Once a day, the sun and the target are diametrically opposite each other as seen from the mirror. The mirror is then edge-on to the light arriving from the sun. Just before this time, sunlight is striking the mirror at a shallow angle, and being reflected to the target. Just after the edge-on condition, sunlight strikes the mirror from the opposite side! So, in order for the mirror to continue reflecting the sunlight toward the target, it must make an abrupt 180-degree rotation. It turns at 7.5 degrees per hour for very nearly 24 hours, but then suddenly turns 180 degrees, returning to the orientation it was in 24 hours earlier. This is intuitively obvious, of course. The earth turns once every 24 hours, so the mirror must return to the same orientation every 24 hours. The time of day when the abrupt turn happens depends on the position of the target. In the northern hemisphere, if the target is roughly to the north of the mirror, the sudden rotation will happen at about noon. If the rotation is not done, if the mirror was acting as a heliostat before the edge-on condition, it will fail to do so afterwards. And it will work on alternate days, e.g. on Monday morning, Tuesday afternoon, Wednesday morning, etc.. (This is assuming the edge-on condition happens at noon.) So if you really want to make a heliostat that works this way, with the mirror turning about a polar axis at 7.5 degrees per hour, you must not only arrange for the latitudes of the sun and the target to be equal and opposite, you must also arrange for the 180-degree turn to happen at the right time each day. This is not going to be easy or cheap! Another approach would be to use a double-sided mirror, but I have never seen such things on commercial sale. You could make one, of course, by sticking two conventional mirrors back-to-back, but then you're back into the cost of having a second mirror. Oh well... David
Apr 3, 2009. 9:40 AMPKM says:
FWIW
I think the 48 hour rotation could work if you rotate a double-sided mirror about an axis that intersects the mirror. To reflect light from the sun towards a fixed direction on the ecliptic the mirror's surface normal (ie pointing straight through the surface of the mirror) has to lie half way between the direction of the sun and the desired aim direction.
As the sun completes a 360 rotation every 24 hours, the mirror has to rotate at half the speed, which we could call 7.5 degrees per hour or 48 hours per rotation. The trivial problem with 48 hours per rotation is that in your setup, if the mirror is in the right position at 4pm one day, at 4pm the next day it will have rotated 180 degrees and be pointing the wrong way- hence the need for a double sided mirror. In this case "48 hours per rotation" might be an easily understandable way of expressing the rotation speed, but in practise the heliostat should turn at 7.5 degrees per hour when tracking the sun and return to the start position during darkness if using a single-sided mirror.
The other case is the reflecting-sunlight-towards-the-poles case, and this trivially needs a mirror that rotates once every 24 hours. My gut feeling from these two cases is that the target being on the ecliptic or the poles are special cases, and reflecting sunlight towards a fixed point other than those requires a slightly more complex rotation. It occurs to me that you could potentially model this rotation with a mechanism a little like a pantograph, but it's a bit too complex to describe in just text.
tl;dr- reflecting to a point on the ecliptic can be done with a 7.5 degree/hour rotation. Reflecting to the poles can be done with a 15 degree/hour rotation. Reflecting to an arbitrary direction can be done with a mechanism employing a 15 degree/hour rotation and a mechanical bisector.
May 5, 2011. 5:01 AMmvencelj says:
The 48 hour idea is perfectly OK! Indeed, one needs a double sided mirror and a 48-hr clockwork and it works a charm. It even would have worked during the night it the Earth was transparent.
cheers!
Mar 30, 2009. 3:28 PMdavid williams says:
Don't worry! I'm not stressed about this. Just intellectually curious. As I said, it is possible for the 180-degree flip to happen in the middle of the day, maybe while you're trying to use your machine for cooking or whatever. As I also said, I have done experiments about this. Only under highly unusual conditions, when the latitudes of the sun and the target are equal and opposite, does a mirror rotating about a polar axis at 7.5 degrees per hour act as an accurate heliostat. Silbermann made his machines in the 1830s. They worked, and still work, beautifully. I saw one offered for sale recently for about $3000. I'm not sure if it was an original or a replica. But there must be a demand for them for this price to be anticipated. Unfortunately, some people misunderstand how they work, and say that their mirrors rotate every 48 hours. They don't. There is a shaft that rotates every 24 hours, effectively tracking the sun, and a mechanism that bisects the angle between the directions of the sun and the target. It's actually quite similar to a device you made a few months ago. I will Google this, as you suggest. David
Mar 31, 2009. 1:02 PMdavid williams says:
I did google it. It agreed with what I've been saying.
Mar 21, 2009. 12:02 PMdavid williams says:
Hi Brian:
Having two mirrors does cause a loss of light, but you can make up for that by making the mirrors a bit bigger. A mechanical heliostat with two mirrors is *much* simpler, mechanically, than one with only one. There's no need for an angle-bisection mechanism, for example. The extra cost of the second mirror is likely to be less than the saving in the cost of the mechanism. This is the opposite of the situation back in Silbermann's time, when mirrors were extremely expensive.
I have never heard of anyone using a heliostat to set up an equatorial mount, or even to find true north,. Finding north using the sun is much more difficult than is often believed. The trick that Boy Scouts learn, using the hour-hand of a watch, is accurate only if you're near the North Pole! Other published methods are also useless. I have thought of using a sundial, with plate and gnomon, putting it on a level surface, and rotating it until it tells the right time. The gnomon should then be pointing north, or south in the southern hemisphere. But the sundial would have to be made for the correct latitude, a clock would have to be available to tell the time, and corrections would be needed for longitude and the Equation of Time. Not simple! Watching the sun's motion for hours as it travels across the sky can also be used, but who want to take hours over finding north?!
So if you can find a way of using a heliostat for this, I would be very interested to hear about it.
Your previous inventions have been very ingenious. I especially like the hydraulic mechanism that lets a small clock control the rotation of something heavy such as a solar oven. I hope your devices are being put to good use somewhere.
Keep up the good work.
David
Mar 10, 2009. 10:29 AMNachoMahma says:
. Cool! Once you get this completed, it should be Featured-worthy.
Mar 9, 2009. 5:56 PMrimar2000 says:
Some years ago, while I design my solar cooking, I made an arrangement with an inexpensive electronic clock, just divided in four the speed of the hour hand with two gears. And it was!
Mar 9, 2009. 12:51 PMkelseymh says:
This is pretty good; thanks for putting it up! I have a few suggestions for extending the documentation, when/if you have the time and opportunity. 1) Add a couple of diagrams explaining about the latitude-angle relation and how someone might do the alignment. 2) Separate the assembly process from the list of materials. I'd put the mirror assembly in one step, the equatorial mount (protractor and base) in another, and the completed heliostat (with some alignment commentary) in a third. That will make it easier for someone else to follow along and build it themselves. As a side note, all your pics are attached to the Intro step, because you uploaded them at once. You might consider, if you wish, removing them from that step; they'll stay attached to the others.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
74
Author:gaiatechnician
I am a stone mason. My hobby is making new solar cooking and gardening stuff. I have used solar heat to cook soil for a couple of years. In mother earth news in January, i read that their compost expe...
more »
