Introduction: Hello World: Your First Othermill Project (Otherplan Public Beta)
Picture of Hello World: Your First Othermill Project (Otherplan Public Beta)
The Othermill is an easy-to-use desktop CNC mill that can fabricate amazing things out a variety of materials, including wood and metal. It's also great for prototyping PCBs for hobby projects or manufacture.
In this tutorial, we use the cross-platform version of Otherplan so you can use your Mac or PC to make a light-up circuit board that displays the famous "Hello World" startup message. The rack that extends from the side of the finished project even gives you a charming yet handy way to store the hardware included with your Othermill. It's adorable and functional!
This tutorial is designed for Othermill beginners, and we will walk you through all the steps.
This tutorial covers:
  • Using Otherplan with G-code (the file is provided in the next step)
  • Getting familiar with Otherplan and the Othermill
  • Using FR-1 as a structural building material
The Othermill comes with all the materials needed to complete this project — the only additional thing you'll need is a soldering iron and diagonal cutters.
Step 1: Materials, Tools, Files, and Skills
Picture of Materials, Tools, Files, and Skills
Here's everything you'll need to build this project:
Tools
  • The Othermillincludes handy accessories like spindle wrenches and end mills
  • Computer running Mac OS X, with Otherplan installed
  • Soldering iron and solder
  • Diagonal cutters for clipping wires
  • Calipers to measure your board (optional). Calipers are available at most hardware stores, are easy to use, and can range in price from inexpensive to absolutely shocking. They're useful for very tiny, accurate measurements, more so than a ruler or by eyeball.
  • Helping hands tool aka "third set of hands," to hold your circuit board in place while soldering (optional)
Materials (all included in the Othermill's Hello World Kit, which comes with the mill)
  • Single-sided FR-1 printed circuit board blank
  • 47-ohm resistors (2)
  • LEDs (2)
  • Coin cell battery, 3-volt, CR2032
  • Coin cell battery holder
  • Double-sided sticky tape
Files
  • HelloWorld.nc, attached in this step
Skills Needed
  • Basic understanding of how a simple electrical circuit works
  • Basic soldering skills
  • Basic understanding of what milling is
  • OR the willingness to pick these skills up while you make this project. It might take a little longer, but if you've never done it before, you'll feel like you just invented fire!
Step 2: Set Up Otherplan and Your Othermill
Picture of Set Up Otherplan and Your Othermill
Follow these steps to set up your mill. For a complete walkthrough of unboxing and setting up your mill for its first use, see our Getting Started guide.
    • Make sure your mill is plugged in to a grounded electrical outlet.
    • Connect the USB cable to the back of the Othermill and to your computer.
    • Download and install Otherplan. To do this, click Download on the Otherplan webpage, double-click the file for OS X or Windows, and install according to the methods of your operating system.
    • Open Otherplan by double-clicking on the icon, which should be wherever you chose to save it.
    • Turn on your Othermill by pushing the power button on the back of the machine.
    • Enjoy the mill's cheerful beeping startup (these beeps sound only when all the windows are in place).
    • In Otherplan, a dialogue will pop up asking you to "Start Homing" the machine. Homing tells the machine where it is in space and makes sure the position of the tool in the machine matches the position of the tool in the software. This ensures that all your cuts are exactly where you want them to be.
    • Click theStart Homingbutton.
    • The Othermill will go through its homing procedure, which will take a few seconds.
    You're now ready to set up your file!
      Step 3: Set Up Your File in Otherplan
      Picture of Set Up Your File in Otherplan
      • In Otherplan, click Import Files and select the HelloWorld.nc file that you downloaded.
      • You'll see a rendered version of the file appear on the machining bed in Otherplan, and the file name should appear on the right side of the screen with some options and buttons below. The material dimensions haven't been set yet, however, so while the file will appear on the top of the material, it will still look strange.
      • On the right-hand side of the screen, you'll see the Configure column, which is made of expandable menus labeled Tool, Material, and Move By, followed by a button labeled Import Files.
      • Expand out the Material arrow, and click on the preset dimensions. They should expand out and provide editable fields for you to enter the dimensions of your FR-1 PCB blank. (Make sure Otherplan is set to view the units you'd like to work with using View > Show Units in Inches/mm.)
      • Use your calipers to measure the width and length of your material. Enter the width as the x value, the length as the y value, and the thickness as the z value.
      • In the Placement bar directly underneath the z value for the material dimension, enter in .003'' (0.076mm) in the z field of the Placement drop-down. This will raise the plan .003'' (0.076mm) to make up for the thickness of the tape underneath the board.
      • Now, in the panel for the plan you imported, select the tool you're going to use to cut out the circuit board. It should match the tool selected in the G-code, which, in this case, is a 1/32'' flat endmill. You can tell by opening the G-code file in a good plain-text editor — the tool is named right at the top. We generated this G-code by exporting it from the other version of Otherplan available from our site, but you can generate G-code any way you like (more on this in our Basic Project Workflow support guide).
        Your file is ready! Next comes the tool setup.
        Step 4: Set Up Your Tool
        Picture of Set Up Your Tool
        • In the upper-right corner of the Otherplan window, click on Set to set your tool. This will lower the z-carriage, making it easier to install an endmill, and it will also bring up a dialogue box to walk you through the tool-changing process.
        • In the dialogue box in Otherplan, click Continue and select the tool you want to use. Make sure to choose the 1/32" flat endmill.
        • Remove the collet from your accessories kit if you haven't already installed it. The collet is the round device with a hole through it that holds your tool in the machine. Fit the collet, wide end first, into the collet nut, the threaded piece on the end of the spindle where you would expect a tool to go. Then, screw the nut loosely back onto the spindle shaft.
        • Slide a 1/32" flat endmill into the collet until just a little bit of the wide part of the shaft sticks out. Then use the two wrenches that came with your Othermill to tighten the collet nut onto the spindle. It doesn't have to be super tight, just snug plus a little bit.
        • Click Continue, and the mill will position the tool over the bed. Since we haven't put the material onto the mill yet, we don't have to worry about where the tool touches down.
          Note: In the future, if you have material loaded before you locate the tool, the machine will go to a spot on the bed it thinks is clear. In that case, make sure the material is truly not in the way, and if it is, double check your material dimensions in Otherplan. Also make sure the tool is not going to sink itself into an alignment bracket hole on the bed. If you are not quite sure where on the bed the tool will touch down, keep your finger on the ESC key and press it if anything looks out of place.
        • Click on Locate Tool. The tool will descend to the surface of the machining bed and calculate where the tip of the tool is in space. When the touch-off is complete, the tool will retract but stay in place above the machining bed.
        Step 5: Put Your Board on the Milling Bed
        Picture of Put Your Board on the Milling Bed
        Now it's time to position your FR-1 in the machine!
        • Expand out the Move By arrow underneath the materials settings. Click the Loading button. This will bring the bed of the mill forward.
        • On the non-copper side of the FR-1 PCB blank, put an even, non-overlapping layer of double-sided tape across the entire surface.
        • Flip the board tape side down, and stick it to the bed of the mill so that the bottom left corner of the board is flush with the bottom left corner of the aluminum bed.
        • Click on the Home button to retract the bed to the home position.
        Step 6: Cut Your Board
        Picture of Cut Your Board
        It's a good idea to stay close by your mill while it's cutting. Never leave a working mill unattended.
        Grab whatever you need to get cozy with your Othermill for the next hour or so.
        • Click the Start Cutting button inside the HelloWorld.nc panel. Watch as the mill cuts the traces, holes, and then outline of the file into the board.
        • When the mill is finished, vacuum all the chips out and click the Loading button. Grab a cheese knife or a putty scraper and gently pry up the FR-1 board as well as the separated pieces that were cut from it.
        Due to occasional variation in PCB blank thickness, you might notice that when the machine starts cutting, it's just grazing the surface of the board; this is fine — it will cut all the way through the copper if you let the job complete.
        Step 7: Add the Electronics
        It's easier to solder on the electronic components before you assemble the pieces together, but it's helpful to understand how the structure fits together before you start soldering on the components. So fit the pieces together using the instructions in the photo below.
        Use this to get a sense of where the LEDs, resistors, and battery holder go, and on which side they're mounted. Once you understand where they go, take apart the model and follow these photos to solder them:
        Step 8: Assemble the Rack
        Now that your parts are soldered, assemble your bit rack once more and solder it all together following these steps.
        • Press-fit the sides onto the front piece just like you did before.
        • Solder the copper tabs that overlap in the joints. There are two tabs to be soldered on each side. These joints not only hold the pieces together, but they also complete the circuit. This allows current to flow from the battery on the left side, through the text on the front, all the way to the LEDs on the right side!
        • Slide the bottom piece of the rack into the bottom slot on the right side and solder the joint.
        • Do the same for the top piece of the rack.
        • Use a piece of double-sided tape to stick the rack base underneath the bottom of the rack.
        • Now that the structure is complete, gently bend the LEDs so they point toward the back of the front piece.
        Continue on to the next step to see if the circuit works!
        Step 9: Hello World!
        Picture of Hello World!
        Slip the battery into the holder so that the flat top of the battery (with the text on it) faces away from the wall of the rack. The LEDs should now be on. Fill up the rack with the hardware and tools you got in your Accessory Kit and use it all day every day!
        Congratulations, you've just made your first project on the Othermill!
        We hope you make many more, and when you do, share them with us! Find us @othermachine on Twitter and also on Facebook.
        Have questions? Check out our Support pages, and if your answer isn't there, email us at support@othermachine.co and we'll be happy to help!
        As always, for more information about new kits, store goodies, stories we tell, and machine updates, check us out at othermachine.co.
        seebobsee (author)2016-06-29
        Nice work!
        About This Instructable
        1,828views
        19favorites
        License:
        Add instructable to:
