Step 3Fuzzy Cloth Helmet Hairdo
- Cut the fabric to strip to length.
- Glue down only the middle the strip from end to end.
- Cut a few notches along the edge of the strip it to help conform to the curve of the helmet.
- Now glue the edges down
Note: the 'foam' part of the helmet is damaged by many common glues. the 'shell' will not have a problem with most glues, if you are not certain you can make a small test patch first.
helmets with plastic shells, especially thermoplastic shells can react to many normally harmless chemicals. So do your homework first when picking an adhesive.
Its best to do your research on your specific helmets construction before you begin. Im sure most of them will react well enough with most chemicals. just no reason to be lazy about it is all.
