Hi, iḿ new to this DIY but iǘe built some of instructables stuff before, now i'm trying to build a 3 axis cnc. Found this simple controller to be connected to lpt port, but I need help identifying the three legged parts on the middle of the circuit, are those npn's? Resistors? What are thoe, can anyone point me out?
Visit Our Store »
Go Pro Today »
This links to a .pdf that gives a better parts list. It's in French but for your question is OK.
Or just search the “ULN2803 stepper”
can't be resistors and capacitors either (they are different shape and have 2 terminals). btw. you do have one resistor in the lower corner of the board between mount and pins of DB connector.
the 3-terminal devices can be diodes, transistors or ICs.
it is not likely to be diodes (unless parallel port is used to read signals).
if the parallel port is used to drive loads (stepper motor for example) then those must be transistors.
you can find this driver on makeyourbot dot org
Since my last reply I've uploaded the plans for one of my motor drivers and Break Out Board.
http://www.instructables.com/id/TB6560-Microstepping-Bipolar-Chopper-Stepper-Motor/
http://www.instructables.com/id/Parallel-Port-Break-Out-Board-BOB/
I've seen just about every circuit and schematic there is on the net, then I made my own. Now I'm not saying mine is the best over all performer or cheapest or anything but it is pretty good all around. IUKWIM
NDS355AN
N-Channel Logic Level Enhancement Mode Field Effect Transistor
http://makeyourbot.wdfiles.com/local--files/brute-force-1-3/sch.pdf
That's the beautiful thing about SMD and today's technology, you can have an equally powerful device in a fraction of the size.
I would assume it's just a unipolar driver. However, I can say that using SMD isn't really necessary and with stepper drivers I personally believe it's better to use DIP sockets with DIP IC's. This helps with maintenance in my opinion, unless of course you absolutely know what you're doing and trust the DIYer to understand just as much when matching the board to motor.
Best of luck.
they seem awfully small to be running a stepper motor
