Helping Out My Car Air Conditioning Again!
2,600
12
Published
Introduction: Helping Out My Car Air Conditioning Again!
About: Update 12 September 2017: A very special thanks to Sam Elder, a manager here at Instructables, who tracked down the cause of my lost publications and fixed the issue. Take a bow Sam!
In the hot tropical climate I call my home, air conditioning is a nice luxury. I demand maximum performance!
In my car I noticed cold air leaking through the feet vents even when the mode selector is on the dash vents. Also I always have the AC on recirculation mode however engine bay heat and outside smell do leak in.
Time to fix these inefficiencies with a can of foam sealant!
Step 1: Identifying the Areas for Treatment.
The feet vents, the fresh air intake and the unused heater core are areas for applying the foam sealant. I want no air or heat migration in these three areas.
For the fresh air intake the cowling needed a partial slide up onto the windscreen to access the duct.
Step 2: Applying the Foam.
A single can of foam was more than sufficient for the sealing of the areas. Now the air blows a bit stronger in the car and the air conditioning is colder!
Not bad for a low cost diy job!
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    Foam like that attracts moisture and traps it against steel body parts causing it to rust.
