SUPPLIES:
-10 Hemma Lights
-10 Air Gap Caps (used to cover the Hemma fixture and hide the threading)
-10 Washers
-10 Eye Hooks
-10 Drywall Anchors (optional)
-Cover (from a lighting & fan store)
-10 Light bulbs
-2 Large Electrical Wire Nuts
-Plastic Cable Ties
-Glue
TOOLS:
-Wire Cutters
-Sanding tool (Dremel or Mouse Sander or Metal File)
-Drill with large bit
-Electrical Wire cutter/stripper
Remove these ads by
Signing UpStep 1Stretch out Hemma cords
Step 2: Cut all plugs off of Hemma lights
http://www.potterybarn.com/products/edison-chandelier/
P(watts) = Voltage (v) * Current (I)
therefore,, I = V/W
I = 120 / 40
= .333 Amps per bulb
Times 10 bulbs = 3 1/ 3 amps. This is for 40 Watt bulbs.
60 Watt bulbs would draw 1/2 amp per bulb, or 5 amps total.
However , with 10 bulbs, I am betting that 40 or even smaller would do nicely.
Nice work
I also tried it using frosted bulbs but wasn't as nice looking and I tried the bulbs that are metallic opaque on the bottom half but those did not put out enough light.
It's a simple fix. A quick look at lowes.com shows 10 feet for about 10 bucks. I'm sure you could find chain for less though.
This is a gorgeous idea.
www.lowes.com/pd_47623-273-5973000_4294934403_
