3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hemma Light Chandelier Hack
Building off of an instructable by "edwinston14" and a suggestion by "piaferre" I created this custom chandelier for our dining room.  It was relatively cheap.  Got it all done for less than $100 with parts from Ikea, Lowes and a local Lighting/Fan store.
SUPPLIES:
-10 Hemma Lights
-10 Air Gap Caps (used to cover the Hemma fixture and hide the threading)
-10 Washers
-10 Eye Hooks
-10 Drywall Anchors (optional)
-Cover (from a lighting & fan store)
-10 Light bulbs
-2 Large Electrical Wire Nuts
-Plastic Cable Ties
-Glue
TOOLS:
-Wire Cutters
-Sanding tool (Dremel or Mouse Sander or Metal File)
-Drill with large bit
-Electrical Wire cutter/stripper
Step 1Stretch out Hemma cords
Step 1:  Open all Hemma lights and stretch out cords to remove kinks (best done overnight)
Step 2:  Cut all plugs off of Hemma lights
22 comments
Jul 7, 2011. 11:55 AMmmestre says:
Sweet! Thank you! I will post pics of my twist on your idea as soon as it's ready. Again, thank you!
Jan 13, 2011. 1:56 PMsanewby says:
here is the Edison Chandelier that someone mentioned above...
http://www.potterybarn.com/products/edison-chandelier/
Mar 2, 2010. 3:54 PMsamandjan says:
looks very similar to the $400 Pottery Barn "Edison Chandelier".  very cool, thanks
Jan 29, 2010. 3:17 PMcloudyerout says:
This looks SOOOOO cool
Jan 21, 2010. 8:24 AMbeccane says:
 This is great but i live in an oooold building. Do i need to be careful what wattage bulbs I use?
Jan 22, 2010. 6:01 PMclarkt says:
You will want to be mindful of the wattage, especially with an older electrical system.
P(watts) = Voltage (v) * Current (I)
therefore,, I = V/W
                   I = 120 / 40
                    = .333 Amps per bulb
Times 10 bulbs = 3 1/ 3 amps.   This is for 40 Watt bulbs.
60 Watt bulbs would draw 1/2 amp per bulb, or 5 amps total.
However , with 10 bulbs, I am betting that 40 or even smaller would do nicely.
Jan 23, 2010. 9:03 AMPagan Wizard says:
With a fixture like this over a dining room table, I would suggest 15 watt incandescent bulbs on a dimmer switch. You really do not want to light up a dining room table for a meal too much, it is better to keep the environment more intimate with lower levels of light.
Jan 28, 2010. 6:38 PMclarkt says:
I agree.   Even 40 watt bulbs would put out a tremendous amount of light in quantities of 10.  However there may be a need for such light at times.    And as long as you are adding a dimmer, you can always cut the 40s down to a dim glow.   Then when you are at the table building your next instructible project, you may want all the light those bulbs can muster.
Jan 22, 2010. 6:03 PMclarkt says:
And oh yeah, it looks cool too.
Nice work
Jan 15, 2010. 9:02 AMDoctor What says:
 Cute!  If you took some small black chain link (or get some chains regular chains and spray paint them black) and fed the wires through it, it would remove the "wire look".
It's a simple fix.  A quick look at lowes.com shows 10 feet for about 10 bucks.  I'm sure you could find chain for less though.
This is a gorgeous idea.
www.lowes.com/pd_47623-273-5973000_4294934403_
Jan 23, 2010. 9:09 AMPagan Wizard says:
I like your idea, but I would suggest the use of plastic chain that can be found at most hardware stores or big box home improvement stores. The plastic chain would help achieve your desired look, but would also be a lot lighter, putting less strain on the wires.
Jan 21, 2010. 8:55 PMcentrd says:
This is awesome. Perfect for the current industrial trend in chandeliers. And at a fraction of the cost! Thank you!
Jan 21, 2010. 7:26 AMpiaferre says:
geniall
Jan 16, 2010. 8:52 AMbobtannica says:
Very neat instructable. Thanks for putting it up. One question... what is a hemma light? I tried googling it and all I discovered is that you can buy them at Ikea. Doesn't really state what it is?!?!? Anyway, thanks again but I would love a definition.
Jan 16, 2010. 3:24 PMbobtannica says:
Thanks! Again, very neat instructable!
Jan 15, 2010. 8:23 AMmonniemoo says:
 gorgeous!
Jan 14, 2010. 8:30 PM! xD ! says:
Although I think putting shades on them might help, I really like the design! Kinda reminds me of the City of Ember...
Jan 14, 2010. 4:57 PMluvit says:
 if i press on my eyes for a minute, then open them, i get the same effect.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:coozerlv
