3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hemma Light Chandelier Hack
Step 7Connect bulbs and you're done
Connect bulbs and you\
Step 15:  Install light bulbs to all fixtures
Step 16:  Turn power back on and test fixture.  If all is good, turn power back off at main panel, screw in cover, turn power back on and you are done.
Step 17:  If you are using clear light bulbs like I did, this fixture is REALLY bright so I also installed a dimmer switch.
3 comments
Jan 21, 2010. 8:24 AMbeccane says:
 This is great but i live in an oooold building. Do i need to be careful what wattage bulbs I use?
Jan 22, 2010. 6:01 PMclarkt says:
You will want to be mindful of the wattage, especially with an older electrical system.
P(watts) = Voltage (v) * Current (I)
therefore,, I = V/W
                   I = 120 / 40
                    = .333 Amps per bulb
Times 10 bulbs = 3 1/ 3 amps.   This is for 40 Watt bulbs.
60 Watt bulbs would draw 1/2 amp per bulb, or 5 amps total.
However , with 10 bulbs, I am betting that 40 or even smaller would do nicely.
Jan 23, 2010. 9:03 AMPagan Wizard says:
With a fixture like this over a dining room table, I would suggest 15 watt incandescent bulbs on a dimmer switch. You really do not want to light up a dining room table for a meal too much, it is better to keep the environment more intimate with lower levels of light.
Jan 28, 2010. 6:38 PMclarkt says:
I agree.   Even 40 watt bulbs would put out a tremendous amount of light in quantities of 10.  However there may be a need for such light at times.    And as long as you are adding a dimmer, you can always cut the 40s down to a dim glow.   Then when you are at the table building your next instructible project, you may want all the light those bulbs can muster.
Jan 22, 2010. 6:03 PMclarkt says:
And oh yeah, it looks cool too.
Nice work
Jan 16, 2010. 8:52 AMbobtannica says:
Very neat instructable. Thanks for putting it up. One question... what is a hemma light? I tried googling it and all I discovered is that you can buy them at Ikea. Doesn't really state what it is?!?!? Anyway, thanks again but I would love a definition.
Jan 16, 2010. 3:24 PMbobtannica says:
Thanks! Again, very neat instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:coozerlv
