Remove these ads by
Signing UpStep 1Step 1
Hammer
Anvil
3/8" bolt/nut
Drill bit or uni-bit or dremel
220 grit sandpaper
silver polish compound
drill
clean rag for polishing
I made myself a small rig for this project so i could easily hold and rotate the coin, but this is not a must.
You'll also need to find a pre 1965 half dollar. 1964 was the last year for 90+% U.S. coins.
Start by lightly hitting the coin on the edge and then rotating the coin using the hex nut as a guide for how far to rotate.
do think that with the propper heat and some silver wire with a dab of nokorrode flux i could sort of tin the ring? i wanted to know if anyoneelse has tried this, because i dont want to ruin the ring that took me so long to make.
You might be better off looking into electroplating it. There are many instructables on this. I really like this solution:
http://www.instructables.com/id/Clean-and-Simple-Electroplating/
Just be sure to switch the things being electroplated (quarters/dimes) with your ring and a piece of silver for the pennies in the above instructable.
Be sure to test this first on a scrap piece of copper or penny before 1982, (in 1983 they moved to a zinc copper alloy but some mints started distributing in 1982) since the ring is valuable to you.
You can find silver quarters at coin shops for around $8-$10 (just get the cheapest ugliest ones, since it is the silver you want). Also some craft stores sell pieces of silver in plate/ring/bar form, you can even buy a silver trinket there. On these make sure that they are made from silver and not just silver plated.
Also a local jeweler may even sell you some of their scrap silver, this may be the best approach since you know exactly the type of silver you are getting.
Good luck and let us know how it turns out!
Any ideas?
YOUR ring rocks man, I love this. It is a nice idea and twist to the whole thing.
I have since made a lot of rings. They are fun to make.
http://www.ringsbyruss.com/photos
also see
Thanks, and keep up the good work!
love the hex shape!
Russ
