3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hex Hats
Hex Hats
Here's a pattern and instructions for two styles of brimmed hats with crowns made from six identical pieces. I like to make these from reclaimed materials. The orange one used to be two shirts, and the brown one used to be two handbags. Once you've made a couple, you can throw one together in about 45 minutes.
The brims are made of plastic rescued from the packaging for a dress shirt. Other possible sources are plastic spiral notebook covers (not the cardboard ones, though) or blister packaging if the product is big enough to have about 6" x 4" of flat (or gently curved) plastic. The smaller brim would probably fit on a plastic milk or juice jug.
The orange one has a zipper on the crown under which you can put any kind of Sekrit Surprize. The zipper was part of the neckline of the original shirt, which I cut to fit. I also like to put pockets on the crown, as I did with the brown one.
This tutorial shows the construction of the brown hat as I'd already made the orange one. However, the technique is almost exactly the same for both, just the pieces are slightly different sizes.
Step 1Materials and tools
Materials and tools
I like to make these hats from reclaimed materials. The orange one used to be two shirts, and the brown one used to be two handbags. Most materials are suitable, except for very thin ones. If your fabric is very stretchy, interface the band so it's more stable.
You can of course also use yardage. You need about 2 or 3 square feet for either hat, which is usually not more than 3/8 of a yard. One shirt would be plenty, I used two only because I wanted a contrast.
I suggest using a lining so you don't get bits of thread in your hair whenever you wear your hat. If you have enough, and it's not super heavy, you can probably use your main fabric. An old t-shirt works well too.
I mentioned the plastic for the brim in the intro. You need some of that.
Finally, you need about 4 or 5 feet of quilt binding, which is like very wide seam binding, an inch wide. It's available in packages of 3 yards in any fabric store. You can substitute another piece of fabric the same dimensions as the band, but I find quilt binding is easier and faster.
Finally finally, you need thread and a sewing machine. No special stitches are required, any old sewing machine will do.
36 comments
Oct 26, 2009. 9:47 AMpleasant.fiend says:
I used the orange hat pattern with the brown hat bill to make a Mario hat for my son's Halloween costume out of craft foam and hot glue.
Aug 1, 2011. 4:14 PMHatsumomo20 says:
Ha ha OMG I love the Mario Hat idea! Great Job!
Jan 30, 2011. 7:29 AMspiralshannon says:
Thanks for a really well done instructable - I'm fairly novice with the sewing machine and my hat turned out great!
Sep 5, 2010. 9:16 AMFoaly7 says:
Somebody needs to make a flexagon hat, that's sorta reversible, but is more than two hats in one.
Dec 17, 2009. 6:13 AMiamunique127 says:
 I love that style of hat but they cost too much to buy a nice one.
I wish I could sew but many of my gender is missing that gene.
Good instructable.
Jul 20, 2010. 11:48 PMcriggie says:
No - your personality is missing the "give it a try" attribute. So give it a try. I'm trying to add a brim to an existing beanie, and doing it by hand sewing too.
Jun 9, 2010. 1:30 AMLionessQB says:
Are there any pictures from someone making the Orange hat?
May 18, 2010. 1:49 PMkjbrasda says:
If you can't find suitable plastic to reuse for the brim, I've found that plastic stencil blanks work great. I made a few more to donate to cancer patients through my mom's art group, including one I modified the pattern for to make it brimless and reversible.
Feb 12, 2010. 5:20 PMisewformoney says:
I have been looking EVERYWHERE for a hat pattern like this. This is EXACTLY what I wanted.  I am almost finished with the orange hat pattern, and while I am a bit confused in some areas of the directions, I am managing to get it right (and I'm a very experienced sewer).  I love the way it looks!!!!  Thanks, Rachel. This is AWESOME!!!  I'm making one to match an Amy Butler (www.amybutler.com) dress I have in progress!
Feb 11, 2010. 1:10 PMsolusetal says:
I am going to be making more than one of these.  I wear hats all the time and like this style.
Shouldn't the carpenter's rule be stated "measure twice and cut once"?
Sep 5, 2009. 1:58 AMkjbrasda says:
thanks for the excellent tutorial!
I made me one from some awesome fabric I just *had* to have when I saw it in the store. I think I'm going to redo my chuckies in the same stuff. lining is small yellow checks
I also made one for my brother and one for my daughter.
http://kjbrasda.deviantart.com/art/hats-112828422
the green one was heavy woven stuff that was a bit hard to work with, the blue a shirt my daughter couldn't wear because ithe fabric was uncomfortable on her skin, ok as a hat though! That fabric forced me to use interfacing for the first time, as it was a bit light and floppy for a hat on it's own.
Sep 7, 2009. 6:15 PMkjbrasda says:
thanks!
Sep 5, 2009. 2:22 AMkjbrasda says:
oh yeah, I made one for my sister too, no pic, but it's black and white plaid with two little bows on pins next to the brim, lining black with pink polkadots.
Aug 16, 2009. 10:08 AMcowscankill says:
LOL. I always put needles in the "wrong" way xD It is always hard to remove the pins, and I end up screwing up the stitching.
Aug 10, 2009. 6:21 PMTulumayan says:
A million THANKS for posting this. I had a book from grade/high school (1970's) that is long since gone explaining how to do this. I made a few hats and remembered some of it but you filled in all the empty spots. I sure do appreciate it. My little GRANDSON is going to have some awesome hats now.
Apr 25, 2009. 11:31 PMbigmark says:
I cannot weight to make one,Mine will be red like super mario. lol for the kids(& me too)lol thanks
Mar 21, 2009. 9:10 PMzzoe says:
Made a hat like this years ago. Old BDU material, oilskinned with Sno-Seal. Wore it for years and LOVED it. Lost the hat, lost the pattern. Sad Zzoe. Now thanks to you sad Zzoe is HAPPY Zzoe. Soon i will make one! THANKS!!!
Oct 1, 2008. 8:02 AMIndie says:
Here's my attempt! I did a little bit of modification -- I used the brown hat pattern, but I made the brim smaller (trimmed the plastic stiffener at the front so that it doesn't stick out as far) and I covered the brim in the same material as the rest of the hat (trouser-weight corduroy). I also skipped the band lining step and just sewed a ribbon around the inside to cover up the raw edges. Thanks for the design -- I finished it in under three hours, and it makes a really spiffy hat that people don't believe is homemade.
Jan 5, 2008. 10:16 PMAlathald says:
Very cool hats, for the patterns in step two you may want to try out Inkscape, it will allow you to make minor adjustments to your lines while you draw without it being a big hassle. GIMP is great for photos and such but for things like cartoons or patterns (any type of linework) Inkscape is the winner.
http://www.inkscape.org/
Dec 11, 2007. 5:59 PMtarziesgirl says:
Well, its my first comment, and my first comment with pictures, so here are the pictures after the second attempt.
Dec 11, 2007. 3:46 PMtarziesgirl says:
Rachel, I finished it! I went back and reread, and reread. Then I took out all of the sewing I did wrong for step 9, and did it again. I want to add a button to the top, but I took pictures to share. I made it for my son for Christmas. I know he'll love it. Thanks so much for providing this instructable with pattern! Oh, and I couldn't resist showing off my old sewing machine with the pictures, I just love my treadle. Erin
Sep 8, 2007. 6:04 AMconnorcancount! says:
just make it red and stick an M on it and you could have a seriously sweet mario hat!
Aug 2, 2007. 5:05 PMLaxLovaLV says:
The links aren't working. Might be my computer but if you could check the would be GREAT! I can't wait to start this project!
Mar 12, 2007. 10:25 PMAdmirabilia says:
I like your hand drawn pattern and consice instructions. Thanks for this, its a good reminder to K.I.S.S... Looks good, I think we oughta stake out a millinery section Fo Sho!
Jan 26, 2007. 8:39 PMjeffreyf says:
Can you make these out of denim? Because if so, you could have some serious 70's Dolemite action going on.
Jan 13, 2007. 7:56 PMoutofthewoods says:
Thanks for posting this! I'm not sure my beginner sewing skills will be able to handle it, but I've got some old denim that I think would make a nice hat.
Jan 13, 2007. 2:11 PMmega_swordman says:
Very nice. I'm glad you posted this, I've always wanted a hat like this. Now I can make one.
Jan 12, 2007. 9:43 PMSurferGeek says:
Huggy Bear would be proud! ;)
Jan 12, 2007. 4:46 PMJezza Bear says:
Wow, I don't know what took longer, the hat making or the Instructable :-) Great modelling at the end, who is she? Get her manager on the phone now :-). Not quite my style but I know my girls will be interested.
Jan 12, 2007. 4:36 PMjeffreyf says:
Excellent Instructable, complete with excellent final picture!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
242
Author:rachel
I'm a founding member of Noisebridge (https://noisebridge.net), a hackerspace in San Francisco, and Ace Monster Toys (http://acemonstertoys.org/), in Oakland. If you're in the area, stop by and say h...
more »
