3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hex Hats
Step 9Line the band
Line the band
You can cut a piece of fabric for the band lining but I always just use quilt binding which is pre-cut and pre-folded to the appropriate size, plus it's lightweight and flexible. It's available in most fabric stores in a variety of colors, mostly boring, but since it's on the inside, who cares?
Cut a piece an inch or so longer than the band, or just start at one end and cut it to size when you're done. Start at the center back, opposite the brim, on the same edge of the band that the brim is on (see the picture that illustrates this). Open out the binding and fold the end down about a quarter inch as in the first picture.
Stitch across the folded-down end and on around the band. Going over the brim is the only hard part, but since you stitched that down already it's not too bad. At the end, overlap your folded bit by half an inch or so and cut off the quilt binding. (And finish the stitching!)
Fold the binding under the band to the inside, pin, and stitch it in place (this seam isn't required, but it makes the final step of attaching the crown easier).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
242
Author:rachel
I'm a founding member of Noisebridge (https://noisebridge.net), a hackerspace in San Francisco, and Ace Monster Toys (http://acemonstertoys.org/), in Oakland. If you're in the area, stop by and say h...
more »
