Hex Nut LED Flashlight by sjroth
Featured
For several years I have been planning on doing this project, but it wasn't until now that I actually tried it. My plan was to make a miniature LED flashlight out of hex nuts, using them as the casing. I would use a matching screw as the cap for the battery compartment, and add a keychain to make it easy to carry around.
Here's how I did it.
Step 1: Supplies
Things I used:
  • Soldering iron and solder
  • Third hand
  • Electrical tape (heat shrink tubing would be much more effective)
  • Clamps
  • Needle-nose pliers
  • Two part epoxy
  • Super glue (Krazy glue would be better)
  • Heavy duty scissors
  • Scissors
  • 6 18mm nuts
  • 18mm bolt
  • 20mm nut
  • Washers
  • White 5mm LED
  • Tactile switch
  • Switch cap
  • Wire
  • Ring for keyring (I don't actually know what that is, I just found it in my junk box)
  • Small spring
  • Positive terminal plate
  • 3 1.5V button cells
Warmtint says: Mar 8, 2013. 4:17 AM
great idea!! It looks really cool. The improvements will make it 100% better.
You do pretty good instructables which is just as much of a talent as the project itself. The diagram you added was a nice touch.
keep 'em coming !!!
imperio says: Feb 7, 2013. 5:37 AM
beautiful! .... but how much it weighs?
Imperio
sjroth (author) says: Feb 7, 2013. 6:27 AM
About 112g including the button cells.
imperio says: Feb 9, 2013. 6:43 AM
maybe ... if you used aluminum ....
sjroth (author) says: Feb 9, 2013. 8:51 AM
Nah, that would be too soft and wouldn't seem as heavy-duty. I prefer the steel, even if it is heavier. And it's not that easy to find aluminium hardware.
kukubee says: Feb 8, 2013. 6:37 AM
Truly amazing! Is it too heavy to put it in your pocket and take it with you on the key chain?
sjroth (author) says: Feb 8, 2013. 6:43 AM
I don't keep it on a keychain because I don't quite trust the epoxy. But if you're confident that it won't fall apart as it's swinging and knocking around, I guess it would be fine.
tritian says: Feb 7, 2013. 4:35 PM
that is amazing!
TSC says: Feb 2, 2013. 12:40 PM
Heavy for a small flash light. But Awesome!
sjroth (author) says: Feb 2, 2013. 7:52 PM
Yeah, I know the weight is an issue, but somehow it makes it seem more heavy-duty.
Chill Pill says: Feb 7, 2013. 4:36 AM
I agree, a little weight on an object makes it seem more high quality and less cheap and flimsy.
bhvm says: Feb 7, 2013. 4:15 AM
How about adding a superflux or even a power LED rather than the puny 5mm ones?
With the whole metal casing, you'll have decent heatsinking even for a luxeon star. Very nice idea tough. Looks tough and IS tough!
racoontnn says: Feb 5, 2013. 10:52 PM
A fun and safe thing to use in the plumbing trade. I often break down plastic lanterns, when to put it together with tools.
c3ralki1l3r says: Feb 3, 2013. 9:48 PM
I would give this a thumbs up ,if there was such button, and well what can i say this would be a good gift the the handyman of the house :D, just don't drop it in to the nuts and bolts bucket.
CR15P33 says: Feb 3, 2013. 8:53 PM
Dude, this would make a nice self defence weapon if you made it longer.
batonas says: Feb 2, 2013. 1:04 PM
rely nice concept 5\5 if your in any contest you got my vote.
sjroth (author) says: Feb 2, 2013. 11:59 PM
Thanks! I entered in the Pocket Sized Contest, and I'm waiting for it to be accepted.
Warfusion says: Feb 2, 2013. 10:17 PM
Very cool looking project! I love the simplicity and size!
J-Five says: Feb 2, 2013. 11:09 AM
It’s very resourceful and ingenious.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
