Step 4Machine the motor linkages
Start by cutting the 12" aluminum block into two ~5" pieces, then drill and mill the holes and slots. The slot is where the motor is attached to the linkage, and the sizing of it is dependent upon the shaft of the motors that you have.
After machining the block, drill two holes perpendicular to the slot, and tap them for set screws (see second image). My motors have two flats on the shaft, so adding set screws allows for extremely rigid attachment of the linkages.
If you don't have the skills or equipment to make these linkages, you could take your part drawing to a machine shop for manufacture. This is a very simple part to machine, so it shouldn't cost you much. I designed my linkage with a flat-bottomed slot (so I could secure it with a preexisting bolt on the motor shaft, as well as take advantage of the flats on the shaft), so that's why it needed machining in the first place. However, this linkage could be designed without a slot but rather a large through hole, so all the work could theoretically be done on a drill press.
The drawing I used for machining can be downloaded below. This drawing is missing the dimension of the depth of the slot, which should be marked as 3/4".
motor_linkage.pdf(612x792) 24 KB| « Previous Step | Download PDFView All Steps | Next Step » |
comments
Add Comment
rpantaleo (author)
says:
rpantaleo (author)
says:
rpantaleo (author)
says:
rpantaleo (author)
says:
Add Comment
