Step 5Weld the frame
The frame uses all of the steel pieces cut in Step 3 except for the Legs and Leg linkages. You may notice that there's a few extra pieces of metal in my frame, but these are not critical structural components. They were added when I already had most of the robot assembled and decided to add some additional components.
When welding the frame, weld every joint. Anywhere that two different pieces of metal are touching, there should be a weld bead, even where the edge of a piece of tubing meets the wall of another. The gait of this robot subjects the frame to a lot of torsional stresses, so the frame needs to be as rigid as possible. Welding every joint completely will accomplish this.
You may notice that the two cross members in the middle are slightly out of position. I measured from the wrong side of the tubing when initially laying out the bottom half of the frame for welding, so the positions of those two cross members are off by 1 inch. Fortunately, this has little effect on the rigidity of the frame, so I wasn't compelled to remake the entire thing.
The pdf files presented here are drawings with dimensions to show the position of components in the frame. These files are also present in the folder with the CAD files in Step 1.
Or it's ok to go with 1" and 2" x 1"? I don't know how robust your frame is. If it's good enough I won't go with thicker square tubing (it's the same wall thickness).
please reply, and also specify if I might mess up the power-to-weight ratio!
Thanks
