Hexafish Rainbow Loom
Published
Introduction: Hexafish Rainbow Loom
About: Hi I'm Amelia and I love to do many things like drawing, running, reading, and creating. :) nice to meet u all :3
Step 1: Supplies
You will need bands, hook, and peg thing.
Step 2: Pegs
You will want to take the middle peg off and leave the other two on there. Like this.
Step 3: Pleaseing the Bands
Your going to put one band on the two pegs on the side. With the arrows facing you.
Step 4: The Beginning
Your going to get the one side of the band (the right most side) and pull it to the bottom left. An it should look like this (image three)
Step 5: Placing the Bands
The your going to get the last side of the band and pull it to the top right peg (pic 1and two) It should look like this (pic three)
Step 6: Placing the Bands
Then your going to make a square an put it on the top of the band u just did.
Step 7: Moving the Bands
Then your going to go under and grab the bottom band (mine is red) and pull it up and over the peg.
Step 8: Moving the Bands
You want to do the same thing to the other corners till it looks like this.
Step 9: Moving the Bands
Then u want to make another square and do the same thing pull the bottom band up and over the peg till it looks like it in image three.
Step 10: Makeing the Braslet
Then make another square and keep teething the steps.
Step 11:
When it starts looking like this.....
Step 12:
Pull it down every now and again. And just lee doing the same steps.
Step 13:
Keep going and don't forget to pull every now and again.
Step 14:
Should be about this long.
Step 15: Adding the C Clamp
A C clamp normaly dose a better job than a S clamp.
Step 16: Adding the C Clamp
Take the bad on the berry bottom and hook it.
Step 17:
Then hook all the corner bands on the c clamp.
Step 18: Finish
All done if you have any ? Just ask :)
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    5 Comments
    It's not called a hexafish it's called a 4 pin fishtail
    Awesome and simple to follow! Turns out great :)
    If anyone has any ? Just ask first instructable :) thanks hope it worked out for y'all
