Step 2: Assembly step 1
Grab one of the drawer sliders and slide it as far apart as it will go. Measure on your arm about how long you want the casing of the hidden blade to be. (mine is about 7~9 inches, i forget exactly how long).
Grip the slider firmly and saw off the extra slider (the wider part)
You should be able to slide the thinner slider part out of the wider one. Do so. We are going to throw away the thinner part, but first we need to get the other smaller piece attached to it.
Bend down the piece shown in the 3rd picture with a pliers. Carefully (and close to the ground) slide off the piece with the ball bearings. Keep this piece along with the ball bearings.
Refer to picture 5 to see what we are keeping.
Go to next step.
EizoLiao says: Jun 15, 2011. 9:43 PM
Lord Maul says: Aug 18, 2010. 6:14 PM
yeah i have a 3 piece slider too what should i do?
joeyay says: Aug 17, 2010. 3:11 PM
all the sliders i could find were three piece, and had a slide that was touching the base, so it couldnt hold nuts. any help?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
