Step 2Glue 'em Together
You may want to remove the outer plastic sheath, and glue the inner paper (using paper glue) onto the cases so that they do not come off later.
Mix the 5 minutes epoxy on a piece of tin foil, (use about half of the entire tube)... must work quickly
Using a spare piece of cardboard smear the epoxy on the sides of the cases... this only needs to be done near the spine region. Make sure not to get the epoxy on the spine for this is the area exposed. The inner dvds receive epoxy on both sides, only spread epoxy on one side of the outside cases.
Once glued, press down and make sure that the cases are all in line with each other. You can use blue tape to help hold them in place... I used my moms watering can.
Add Comment
