My home office was messy. After I am done it will still be messy but now it is finished AND it has the secret feature. Well it was secret, till I wrote this.
In one wall of my home office is a 5 feet tall 2 feet wide door to access the storage area and crawl space under the garage. This is where we put holiday decorations, old stuff, and junk.
This wall was the perfect spot for floor to ceiling bookshelves, which I have done lots of, but it had this door in the middle of the wall. The perfect answer was a bookshelf that opened.
One day my father in law visited and we started drawing pictures of how book shelf hidden door could work, how to hinge, where to hinge, how to hide opening, etc. Following are the highlights from the journey that followed.
Step 1: Calculate dimensions
With a pin I tried different pivot ideas, validating my measurements. The goal was to have the vertical gap between moving shelf box and fixed shelves be covered with a single 4.5" trim piece.
I added a better drawing of the key part of the unit, the moving center. The left and right side shelves are not to scale. This was made with visio, which lets you adjust the rotation point, so i could simulate the shelves opening to show clearance.The visio file is attached if can read it. the close up is where i notched the vertical trim to allow the horizontal trim to pivot "through" it.
---Ken
Step 2: Door Frame - moving steel frame
The steel frame would pivot on a upper and lower anchor point, mounted to ceiling and floor respectively.
Step 3: Installing frame
This let me position and place the top anchor, base anchor, and frame. I attached top anchor loosely letting it rock, slipped in frame and bottom anchor on pin (with 2 washers on pin above bearing), then slid the whole set into place. A plum bob hanging along the edge of the frame made it quick to tell if it was vertical in both directions. When true, I secured bolts on both ends. I tested the swing of the door frame with ~500 lbs of people standing in it. Dead smooth action.
Step 4: Add the wood
The 4.5 inch trim left and right of the shelf-door, the right side is fixed to the fixed shelf, the left side moves with the door.I had to bevel notches in the trim on the right because the horizontal trim dives under it as the door opens. I also had to slightly round the horizontal pieces to slip underneath smoothly.
I am not the best woodworker, and the materials ( mdf and particle board ) are less than optimum, and the walls are crooked, but the results were great. Nobody would ever see the finished wall and think "Hey I wonder if that is a door?"
all in all i have about $350 in the project.
Visit Our Store »
Go Pro Today »
You mentioned that you bolted the angle iron to the floor; is this your foundation that you mounted to? Could you elaborate on the type of bolt, depth of holes, etc used to support the weight? Given that (I assume) this is your foundation, was there any risk of structural damage?
Great job, kenbob!!
I'm going to combine these two to make a Secret Bunker Under my House with a Bookshelf door. It will be AWESOME! I will post a video when it is completed and when I find a good house to do it with.
One thought that I recently had while installing baseboard in my house. I painted my baseboards white like your bookshelf and later realized that if they had been a darker color or dark stained wood the gaps wouldn't have shown as much. just a thought to help hide your door.
I appreciate your instructable, i hope to build one to hide my staircase.
thanks.
What is the depth from the front face of the bookshelf to the plywood at the back?
Sorry to ask so many questions, Your design is so well thought out that I want to make my measurements as close to yours as possible.
Hope this helps.
To allow the door to open and close I notice that you refer to the cabinet "passing through" the trim and that it has a 45 degree angle on it. Do you have any additonal close ups of this, either additonal diagrams or photographs showing this? Any images showing this would be greatly appreciated.
Just one other question, did you use 3/4" MDF / particle board (18mm) or 1/2" (12mm).
Thank you for your help with this.
I attached crown to the ceiling, then custom cut top trim on the cabinet to set "one credit card" thickness below the crown.
On the floor i just used 2.5" trim along the base, then cut a strip short enough to clear this ( about 2" ) and placed it on the floor inset as far as possible. looks like a toe kick area... if you lay next to the cabinet on the floor you could tell there is a gap back there,,,, but my floor is too cluttered to allow that:)
Check the pictures above for the close up of the trim gap cut.
Thanks for the PDF, and the explanation, it is exactly what I need and is greatly appreciated.
Randy
Thanks for the kind words.
I think the basic idea could be easily modified to be a safe room door. It will absolutely support the weight of steel or cement.
Lots of folks below have suggested ideas for “hidden latches”.
As to a reliable, easy, convenient, and undetectable lock mechanism: My favorite idea is a variation of the magnetic latches they sell in the baby proofing section. A strong latch is located behind a panel. This latch is released by placing a powerful magnet on the outside of the panel. In practice this would be a “paperweight” that is sitting on the shelf. By placing this paperweight in the right spot on the shelf, the latch is released, and the door can be opened and closed freely. If the weight is moved, the door latches when closed. To work the latch must have a slight bit of free play, so I would include a light magnetic stop to keep the door from being able to rattle against the latch ( not that 300 pound doors rattle much) and it would also keep the door in position to allow smooth release of the latch( an almost balanced mechanism with strong magnet mounted on pull part.
I think I might have to try this:)
Anyway that is a cool solution, all this talk has made me want to build another bookshelf door to the downstairs bedroom. I'd like to use your rubber wheel idea if it's okay with you. If my wife doesn't kill me at the suggestion I can make a ible about it.
The remote switch is a nice touch. Gives me a few ideas for modifying a regular doorknob latch. With a rope or cable, I could turn the mechanism for a doorknob latch by attaching an armature or just using a lever handle doorknob inside the wall. That way two cables (one for the inside also) could open the door. In the old movies they attach the latch to a candlestick because it's camouflaged with the decor. I have a thermostat on the wall right by the door. I could make it so that by tipping it the door would open!
