Hidden GoPro Security Camera
43,042
89
12
Published
Introduction: Hidden GoPro Security Camera
About: Making for the Sake of Making
The Hidden GoPro Security Camera was inspired by Sherlock's hidden camera in the CBS show Elementary. Above, Sherlock is seen extracting video soon after his home was breached by an intruder. What if an intruder breaks into your home and steals all of your belongings? Better hope they don't steal your calculus book too!
Step 1: Materials + Tools
Materials:
  • GoPro Hero 3 or later. Hero 3 or later is required because of the loop setting
  • 64GB+ micro SD card
  • Book. Want a thick enough book such that the GoPro will fit easily
  • USB mini-b cable for GoPro. Maybe even use a USB extender
  • USB wall charger. Want 5V, 1A wall charger. Below 1A and your GoPro will drain faster than it will charge
Tools:
  • box cutter
  • electric drill
  • 7/8" drill bit
  • wood cutting knives (optional)
Step 2: Prep Book
Turn to the middle of the book. Use the GoPro for reference and measure where to cut. You want to leave enough space on all sides of the hole so that the pages don't fall apart. You also want the hole large enough to easily fit the GoPro so leave plenty of space around the GoPro. Begin cutting. This can take a while but be patient. After you have a significant hole in the middle, start cutting from the beginning of the book or the end. Occasionally check that your GoPro fits. No? Keep cutting. Now that your GoPro fits and you can close the book, mark where to drill. Begin drilling from the inside. Once you've penetrated the cover, finish drilling from the outside.
Step 3: Prep GoPro
Follow the steps below to set your to loop video. This will generate 15min video clips and overwrite previous clips once the memory card fills up. My 64GB micro SD car holds 17 15min video clips for a total of 4:15 hours of video. This is with the video set to 1080p, 30 fps.
  1. Turn on (Mode)
  2. Go to Settings (Mode x4, Shutter)
  3. Go to Capture Settings (Mode x5, Shutter)
  4. Go to Loop (Mode x3, Shutter)
  5. Select MAX (Mode x5, Hold Shutter)
Once the GoPro is setup, hit the Shutter to begin recording and connect the cable. Depending on your cable and hole, you may need to cut a groove in the book.
Step 4: Enjoy
Place the GoPro with cable in the book. Connect the cable to the wall charger and place the book in a bookshelf among other books. You do have other books, right? It would look pretty silly without other books.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    12 Comments
    I have a gopro HDHERO2
    1)can you explain any differencesI N HERO2 and Hero3 in obtaining loop videos???
    2) I would like a motion activated sensor to turn on the GoPROhero2 any instructions???
    Thanks in advance
    I say Hero 3 or later because I don't believe Hero 2 has a loop video option. However, there's probably a hack out there somewhere.
    Wow! I can barely see the HUGE HOLE in the book! Such stealth, much hidden! ROFL.
    Nice tutorial! BTW, try connecting the GoPro to a huge powerbank. This way you can record for days with the loop feature on. ;)
    That's an excellent suggestion. Right now, I just have a not-so-hidden cable running from my book to the wall outlet.
    Why have you destroyed such an interesting book? :((
    as an applied math student, I can confirm this book is more useful now than before... ;)
    Trust me, given my book collection, this was the least interesting book I owned.
    Ah ok, if that's the case :), interesting guide by the way
    Lol I also need a "security" cam when my gf stays over
