Hidden Heated Cabinet.
2,849
29
Posted in WorkshopOrganizing
Introduction: Hidden Heated Cabinet.
Step 1:
I had a pegboard in my garage with some unused space behind it. I wanted to make a cabinet for storing spray paint and for charging cordless drill batteries.
Step 2:
I cut out the pegboard in between two joists, gaining an extra 4" of room.
Step 3:
Added a 5/8" piece of old plywood for the back and side of the cabinet and sealed a small gap at the bottom with a piece of trim.
Step 4:
Built a fairly simple door out of the piece of pegboard I originally cut out, more 5/8" plywood and some scraps I had laying around.
Also lined the cabinet with some cut off carpet for insulation and snaked some power in there for a lightbulb.
The bulb will keep the cabinet significantly warmer during the winter to keep the batteries for my cordless tools warm and anything else I don't want to freeze.
Step 5:
Step 6:
Step 7:
Step 8:
That's it. Vote for me in the hidden cabinets contest if you like it.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    3 Comments
    I'm just using one 100w bulb now. It's so cold out that it keeps the cabinet around 5 degrees C. You can actually grab onto the bulb, which obviously you couldn't normally do to a 100w bulb. You're right though. A thermostat would help out a lot if it wasn't so cold here lately
    Nice idea for any unheated shop, but I would recommend using a thermostat for the bulbs. Lightbulbs can give quite a lot of heat, and you do not need the cabinet to be 70°C (158°F), which is what my two 60W-bulbs can achieve easily in my heating cabinet. Also, you will save quite a lot in electricity that way.
    Thanks for sharing!
