Step 2Setting Up Your Files/Non-Laser Alternatives
When you are printing a document you can overlap whatever shapes you want and the one on top prints. When you are using a laser it will cut every single line in your document. Learn to use the "pathfinder" tool panel. Your file needs to be something that will fit together like a puzzle.
Think about the wood grain direction for your pieces. I turned all of the pieces of my compass rose to point the same direction when lasering so that the grain would form a 'starburst pattern.
Have extras of your tiny pieces cut. It's hard to keep all of the small parts together and unbroken. This also gives you options if the grain is inconsistent.
I included a .dxf file and .jpg file of the parts I used. Let me know if you'd like a different file format and I'll try to accommodate!
I had my plywood laser cut because I don't have the tools to cut it as accurately as I'd like. I used interlocking corners because that helped keep the sides square and gave me a large amount of glue surface area. It's good to clean up any dark areas on the plywood with a little rubbing alcohol. The dark areas are carbon and oils from cutting the wood and can make it harder for glue to adhere.
*Non-Laser Alternatives*
I dug through my toolbox and came up with a couple ways to do this if you don't want bother with having parts laser cut.
Alternative 1:
-Plan your veneer panels with minimal curves (the crests work, but anything like the mermaid would be a challenge).
-Print out your design/copy it/whatever and cut it up into pieces.
-Cover your veneer with a low-tack painter's masking tape. This will help stabilize your veneer against the various pressure you'll apply to it. Don't press down on it too much or it will be difficult to remove.
-Trace your pieces onto the tape (keep your grain direction in mind).
-Cut with scissors. Sharp, large, ordinary scissors worked the best for me. 'Cut through a penny' style scissors cut easier but because they are bulkier it's hard to get very sharp curves.
-Cut details with an exacto style knife. Knives are harder on your hands because of the pressure required to use them and tend to get caught in the grain. They are also more dangerous for obvious reasons. Save this for anywhere it's not reasonable to cut with scissors. Keep a lot of fresh blades on hand and change them regularly - you want to cut through the wood, not crush it. My first choice is a high quality snap off style knife. High quality blades last a lot longer than cheap ones do (at least for me) making the initial price worth it in the long run.
-Peel the masking tape off and follow along with the contact paper. Leave the veneer flat and peel the tape when you remove it.
Alternative 2:
I tried a jeweler's saw and was able to cut the veneer very smoothly with that. Use a fine blade and let it cut - don't put any unnecessary pressure on it to avoid breaking the veneer. This will give you more detailed curves than the other alternative, but it takes a lot longer and I would guess most people don't keep a jeweler's saw around. A coping saw might work as well but I'd use the smallest available blade.
mermaidparts.dxf600 KB| « Previous Step | Download PDFView All Steps | Next Step » |
comments
Add Comment
technoplastique (author)
says:
says:
says:
Add Comment
