3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hidden USB Storage
Hidden USB Storage
If you're like me, you may or may not have secret files plotting world domination and other devious deeds. These files obviously need to be hidden from the prying eyes of sisters, FBI agents, grandparents, etc. We are going to convert a phone jack in the wall into a secret USB memory device.
Note: I am not responsible for any illegal files or folders hidden on this device. Use your discretion before downloading any content you may believe to be illegal.
Now, with that out of the way, lets start building!
Step 1What You Need
What You Need
I did this project without spending a dime. If, however, you aren't privileged to have a box full of miscellaneous wires, you may have to buy some cheap items.
Ingredients:
1. Quality USB cable - I used an old iPod cable.
2. RJ-45 cord - Make sure there are four wires inside by looking through the clear connector. If you only see two wires, find a different cable.
3. A USB extension cord - make sure one of the ends is female. (You can go without this but you will have to break open your memory stick, and mess around inside...not suggested.)
4. USB stick containing your secret data.
5. And finally, the phone jack from the wall.
Tools:
1. Zippo or a different, inferior lighter.
2. Shrink tubing - If you don't have some of this stuff around the house, you should be ashamed of yourself.
3. Knife or wire strippers.
4. Screwdriver.
5. Solder and soldering iron.
460 comments
1-40 of 460next »
Feb 15, 2012. 4:13 PMwaterlubber says:
or, put a relay so when the phone line is connected and the reed switch is OFF (allowing phone, no USB)the relay activates putting on a HUGE resistor, usb saved! to access, use reed switch to kill phone.
Feb 15, 2012. 4:11 PMwaterlubber says:
Remote Storage Method:
You use an arduino w/ ethernet sheild
Connect ethernet to any ethernet port in house.
connect rest of wires to arduino
make program
connect to server joo made then plug in custom cable
OR...
Set up a "special" wiring system in your house, not connected to phone or ethernet. do the instrucable. ta da!
Jan 19, 2012. 8:48 PMEverett_McKinley says:
wicked idea.
Jan 19, 2012. 8:46 PMEverett_McKinley says:
shrink tubing is awesome, but black tape should work just as good.
May 10, 2010. 5:20 PMmjzmjz says:
really good idea, 1 question, can I put the usb drive in a live phone plate? Can I use the phone on that line, then unplug the phone, then use the usb drive?
Nov 22, 2011. 10:08 AMbiomech75 says:
If you put the flashdrive along with the live phone box the power that the live phone connection has could damage the drive
Jun 1, 2011. 5:40 AMcparida says:
are u mad?
Jul 16, 2010. 5:32 PMTrippingJimmies says:
This would work with an RJ-45 (8 wire) connection. You setup the phone on the blue pair of the jack and the USB on any of the four wires.
Nov 10, 2010. 7:02 AMbeehard44 says:
or an ethernet port. The ethernet port only uses 4 wires,leaving you with the other 4 (just make sure you aren't using power over ethernet)
So if you use wall mounted jacks, you can easily make a special cable to extract your precious files while leaving it useable for internet with a regular unmodified jack
Jul 13, 2010. 2:13 AMTithen says:
you could drill a small hole then feed the wires for the usb through and wrap them around your phone cable and maybe put a bit of tape around it and connect the wires to a usb male. kinda like when you have a wireless keyboard, the wires are kinda joined but split up at the end for the ps2. does that makes sense idk how to explain it.
Jun 22, 2010. 6:48 PMhoonflap says:
maybe wire a bunch of reed switches (4 closed when no magnet for phone and 4 open when no magnet) for the phone and the usb, then put a bar magnet across the front as your "key" to access the usb. phone jack should still work when plugged into a phone with no magnet present.
Jun 3, 2010. 1:21 PMToki Wartooth says:
I'm pretty sure that wouldn't work. I'm assuming you would splice the phone line and the USB line together and terminate it at the phone jack. Phone lines carry a little bit of electricity so with it added to the USB power output from the computer's it would probably overload the little USB stick. Even if it didn't fry it the electrical signals from the phone line would make some kind of background noise that the computer probably couldn't ignore.
You could always get a dual jack phone plate though. ;)
Sep 20, 2010. 7:57 PMaccount3r2 says:
"Phone lines carry a little bit of electricity..."
a little bit? phones carry around 60v dc idle and 120v ac ringing
Jun 1, 2011. 5:41 AMcparida says:
enought 2 kill u!!!!
Apr 4, 2011. 3:51 AMelectfire says:
I nave never measured more than 10volts DC on a phone line - but then again that maybe something that varies by region.
Sep 20, 2010. 8:18 PMToki Wartooth says:
Yes, you are right it. It is more than a "little". My point still stands though. It's not the 5 watts necessary for a USB device.
Apr 16, 2012. 3:58 PMsnowluck2345 says:
*volts. that would be one hot flash drive if it was 5 watts
Sep 21, 2010. 2:42 PMaccount3r2 says:
yeah, i guess so.
Jun 22, 2010. 7:08 PMjunits15 says:
it should be fine, as long as the switches are spdt and assuming you dont want to use the phone and usb at the same time :)
Aug 16, 2011. 8:46 AMspikey011 says:
loved it!!
Jul 19, 2011. 8:14 AMboyrock375 says:
i really loved this instrucatable and decided to go all out...i had a cluster of conections in my wall so i disconected what i wasnt using and put a 500 gig hard drive in there....one of the small ones that runs off usb power and cover it all back up to look like normal =^.^=
Jul 9, 2011. 12:07 PMjacques3 says:
that is superb for hiding usb's and what would look real cool is an ethernet version and ethernet led torch sorry if it is mean but those above are superb ideas.
Jun 17, 2011. 7:47 PMJamez Britton says:
This is an absolutely brilliant way to hide stuff. Really good idea!
Nov 5, 2008. 9:56 AMChadworkz says:
I use that EXACT Zippo and that EXACT Jump-Drive...too cool (weird?)!
Nov 9, 2008. 6:03 PMtbird45039 says:
me three
Apr 27, 2011. 8:16 PMduct tape says:
me four
Mar 25, 2011. 2:42 PMcamocam says:
why not just have the flash drive and use it normally but then place the flashdrive in it to hide it like get some sort of phone box that opens with a hinge in it
Mar 21, 2011. 12:59 AMdvondrasek says:
or use that wasted end from the adapter
Feb 20, 2011. 8:04 PMfundamoboy says:
wow it's impressing
Feb 8, 2011. 10:31 PMBakaTanuki says:
Well I tried it, and can not get it to work. This is my second wiring job, and these tiny wires are a bit fragile. I think my wiring is just too messy, with little broken bits.
Feb 8, 2011. 11:15 PMBakaTanuki says:
haHA! nevermind, I got it working. My theory was corrent, and after several failures and cutting the wire back more- I got it. My wire is thinner then what you show, and was tricky but my pocket knife skills won in the end. Great tutorial, sir, this will be a nice addition to my collection of secret data storage methods.
Nov 13, 2010. 10:41 PMbmw2go11 says:
You could have de-soldered the usb port off the flash drive, cut the 4 short cables existing on the phone jack and soldered them onto the remains of the drive.
That would cut out the need to buy a female usb cable, and transfer speeds would be a bit quicker.
Jan 27, 2011. 12:06 AMadrian.robb says:
Care to explain why it would be faster? I don't see any reason apart from about 2" less cable, which would make a negligible difference.
Dec 22, 2010. 10:35 PMShadowAssassin says:
I love how I was reading on how to make a dead drop right before this :P This gave me the idea for new capabilties of dead drops... world domination just got one step closer :'D
Oct 26, 2010. 1:58 AMnickboy98 says:
GOOD WORK!!! that is the smartest thing i have seen in ages
Aug 22, 2010. 11:32 AMaly1995 says:
CAN ANYONE TELL ME WAT IS THE PURPOSE OF DIS THING.............=(
Oct 8, 2010. 6:21 PMAndrewlarson says:
for storage but if you dont know you need not know or worry
Sep 30, 2010. 4:37 PMlombax989 says:
This is so cool it hurts!
Sep 26, 2010. 3:33 PMcyberguy91 says:
This makes me think of the wall plates that you can buy with the key "lock" switch on them. I think they were originally made to keep the kids off of the dial-up Internet without having the key. You could use one of those, and then you would have to have the key as well as the custom cable. lol.
Sep 13, 2010. 9:29 AMmginder says:
flargman98,
did you connect the phone lines from the rest of your house to the wires on the jack mount? if you did that is why it fried it. im a telecommunications technician so i know that at your phone lines at idle you will have 56 volts dc and ringing 94 volts dc. your usb drive is rated for 5 volts... : ) this is not to be connected to the house. its just suppose to hide the drive, not give you remote storage
1-40 of 460next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:stonehenge360
