Step 4Solder, Shrink, Repeat
Now grab the phone cord, and cut off one of the ends leaving about 2 in of wire. Strip the outer casing and strip each of the four wires. (2nd pic)
Take a piece of shrink tubing slightly larger than the iPod cable, and slide it down to the end of the iPod cord. Make sure you do this first, or you will have to undo your solder joints to put it on. Now take some small shrink tubing and slip it over one of the small phone wires, twist corresponding USB and phone wires together, and solder. Don't use too much solder or the shrink tubing will not fit over the joint. After soldering, slide the shrink tubing over the joint and shrink with your nifty Zippo lighter (or a heat gun). Repeat this for all four wires, matching the colors like you did in step 3. (3rd & 4th pic)
Remember the large shrink tubing over the USB cable? It's time to slide it over the entire joint creating a semi-professional finish. (5th pic)
10
comments
Add Comment
stonehenge360 (author)
says:
Add Comment
