But what if I make it "invisible' or "transparent" then even if found it looks just like the background!
Try this trick on most any OS. Note this is not foolproof but along with locked, hidden and passworded/encrypted folders is very helpful and very safe from command line browsing as the directory/folder names are not "typeable" with any US keyboards...
Vista works similarly but seems to leave behind a "ghost" image?...hum...?
Erck
On the note of security don't collaborate with people you don't know about, ok? I can remove this from the face of the internet but it won't do me much good. ~llama13
'Security sux that's the point. Dude collaborate...not deface...add some value and post some results or do some test. YOU JOINED the GROUP so you get to see what I contributed to the site ...noobs... what did you post? 'ERCK
Remove these ads by
Signing UpStep 1Overview - OS versions & Variations
Windows XP - no Media or Language support - Use ASCII codes in the name field with "num lk" keypad then 'alt'+0160 in the Name field from the Properties tab "New Folder".
Windows Media Center - varies see above or below
Windows Language support - use "right click" and insert Unicode in the 'New Folder' clear text from name field under the Properties tab.
Vista - has similar variations between ASCII, UniCodes and language options that vary by install and country of origin.
see below...read on for examples, screen shots & limitations.
![C:\Documents and Settings\Administrator\My Documents\Cropper Captures\CropperCapture[15].jpg](http://img.instructables.com/files/deriv/FVW/VBAH/F0R12VU3/FVWVBAHF0R12VU3.SQUARE.jpg)
![C:\Documents and Settings\Administrator\My Documents\Cropper Captures\CropperCapture[21].jpg](http://img.instructables.com/files/deriv/FIM/KWYV/F0R12VU5/FIMKWYVF0R12VU5.SQUARE.jpg)
![C:\Documents and Settings\Administrator\My Documents\Cropper Captures\CropperCapture[3].jpg](http://img.instructables.com/files/deriv/F6B/NP1A/F0R12VTQ/F6BNP1AF0R12VTQ.SQUARE.jpg)
![C:\Documents and Settings\Administrator\My Documents\Cropper Captures\CropperCapture[5].jpg](http://img.instructables.com/files/deriv/FYK/16JK/F0R12VTR/FYK16JKF0R12VTR.SQUARE.jpg)
- i have a laptop.
- i dont get the"
<Windows XP - no Media or Language support - Use ASCII codes in the name field with "num lk" keypad then 'alt'+0160 in the Name field from the Properties tab "New Folder".
" if you could tell me what exactly this means, i dont have unicode.
http://www.instructables.com/id/SAEPSY3F1B3RBOT/
perhaps an instructable on <ctrl>-c and <ctrl>-v
If I have your password I still cannot 'find' your hidden files. ANY COMPUTER you can get to the 'console' can be easily hacked, boot in single-user mode on UNIX or use D: recovery partitions on a PC/Laptop...
Protect you physical machine even better than your web, network or virtual ID's.
E
We're sorry, the URL http://www.instructables.com/id/SAEPSY3F1B3RBOT/ is either incorrect or no longer available.
If you followed this link from outside of one of our sites, we'd appreciate if you'd let the owner of the referring page know.
If you followed it from within our sites, or if you believe you received this message in error, please send e-mail to webmaster@instructables.com and let us know that you got error 404 looking for http://www.instructables.com/id/SAEPSY3F1B3RBOT/ which was linked to on page http://www.instructables.com/id/S242TTMF0R12VUW/?comments=all
