Hide Away Sword Practice Post
Published
Introduction: Hide Away Sword Practice Post
This is an idea for a removable sword practice post that even a wife (or parents) won't mind in the yard..
simple,rugged, and when practice is done the yard remains looking neat.
Step 1: What You Will Need
Materials.
10' 4"x4" pressure treated post
Composite decking post sleeve
Composite decking post cap
Small area rug
5lb box of roofing nails galvanized.
1x1 railing spindle
Tools.
Post hole digger
Hammer
Saw
Marker
Step 2: Dig a Hole
You need a post hole digger for this step.
Dig a hole 3 feet deep or more.
Simple
Tip. There is a trick to using a post hole digger when going deeper than 3'.
Give it a moderate jam down, but then twist it a back and forth to break up the earth. Do this a few times before bothering to retrieve earth.
If all else fails retrieve loose soil by hand.
If you have read this far and have stubby arms your outta luck.
Step 3: Set Post and Post Sleeve in Hole
Step 4: Mark Sleave
Make sure the post sleeve is seated firmly in the hole and mark it about a half inch below grade.
Examine the post cap to guage exactly where to cut it. You will want the top of the cap to be flush with the ground when the post is removed so that there is no tripping hazard.
Step 5: Cut Sleeve to Length
Any saw will do.
Be careful !!!with power tools while cutting plastic.
If you do not go slow and steady certain materials will shatter and fling shap shrapnel.
Always wear safety goggles
Let the saw do the work, never muscle through a cut
Step 6: Level Your Post
Or rather plumb your post.
You do not need a level! I left mine at work.
No worries
TIP:
Close one eye and move your head so that you can use an distant object (like the corner of a house or bird feeder) as a plumb reference.
Do this from at least 2 angles preferably 90 degrees apart.
If you are building your training post in the woods, create a plumb bob out of your shoe lace and a rock.
If you are wearing moccasins, rip out your hair!! ,,...and weave a rope from it for a plumb bob.
Step 7: Fill and Tamp
Backfill the hole while maintaining the post level. Leave the post in to prevent dirt entering the sleeve.
Make sure to compact the dirt constantly with each shovel full using force to create a a solid base.
Step 8: Stop Fill Before Grade
Continue fill until a few inches from top.
Step 9: Place Cap
Remove practice post and install safety cap.
Fill in leaving a finger hole or 2 I. The dirt alongside cap for removal purposes.
Step 10: Enjoy Your Post
Train daily!
Step 11: Optional
Install carpet for a sword saver with roofing nails.
Tack it , wrap it , and nail it off.
I chose to install it inside out, but it's getting beat up already. Next time I'll try shag out.
Step 12: Inspiration
Go youtube
"Armored Combat League"
"IMCF"
Or
"Pensic wars"
For inspiration!
  • Casting Contest
    Casting Contest
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
Very nice sword post, I can see very few people minding it and it working well for practice!
