Remove these ads by
Signing UpStep 1Tools and Materials
1. Grinder with cutting wheel - I needed to use this because my wall had tile. If your wall is drywall, you won't need this.
2. Utility knife - I use this to cut the drywall.
3. Screw drivers - I use one flat and one phillips or star screwdriver.
4. End cutting wire cutters.
5. Voltage tester
6. drill with 1/2" wood drill bit
Here are the MATERIALS I used
1. Double gang or Douplex electrical box. I used a modified "new work" box that is made to be nailed to the wall. You may want to use a "old work" box that holds itself to the drywall.
2. one Electrical outlet
3. one Cable outlet
4. additional wire (Romex)
5. Douplex cover
6. Plexiglass
Additional items you may need:
Wire nuts for joining wire ends
TV cable connectors
comment
Add Comment
Add Comment
