3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hiding Your FasTrak, EZ-Pass, or Other Toll Tag in Your Car
Step 4Opening Your Toll Tag
Before you open up your car or the tag, start by writing down any and all serial numbers, product codes, account numbers, or anything else on the outside or that came with your tag. Once it is inside or disassembled it will be harder to get. You'll want to have these encase you need them later.
The other thing you will want to do before you take things apart is make sure the tag works, and what it sounds like or how it operates when you use it. This is important so that you can measure your success.
Disassemble the case. Be careful you will need to use the case later for testing. My case was your standard plastic variety that was snapped & glued together. Using a thin knife, break the glue seal by sliding the knife between the two halves, and moving it all the way around the outside. When you've broken the plastic all of the way around, start prying apart the two sides. start on a long side in the middle to get a feel for it. Slowly move your way around the outside. If you do a great job, you'll be able to seal it back up and get your deposit back more easily later.
Open the case and remove the tag. In my case, the tag was stuck to the bottom with a piece of double sided tape. After a little prying on each corner, it came right up.
It should look something like this:
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:The DNR
