High Contrast Leather Laser Etching
 by the5thfool
Featured
The hip flask pictured here cost only $5 at the local super-jumbo-extreme-retail store on clearance, and I wanted to personalize it a bit.  I have access to a laser cutter/etcher through the TechShop and thought this might be the tool for the job.
However, one of the problems with cheap, thin leather is that the dye has soaked all the way through the material.  This makes most laser etching into such material difficult to see.  So this Instructable details a series of novel steps on how to etch such leather to produce a high contrast design.
Materials and Tools:
- Dark dyed, cheap, thin leather
- Painter's masking tape (I used the 2" wide blue stuff, good because the lasers cut it nicely and it's not very sticky, important for later steps)
- Light colored spray paint (I used silver metallic)
- Duct Tape
- Laser cutter/etcher
- A design (preferably monochromatic, without too many gradients.  Think b/w clip art or vector art)
Step 1: Etch your Design
Cover the area you wish to etch with the painter's masking tape.  Make sure it's adhered smoothly and try to minimize the amount of overlap between pieces of tape.  Put the material into the laser etcher, and print out your design.  TechShop provided the settings for their laser cutters, but these may vary depending on the machine you are using.  For an Epilog 60W, I used these raster settings:
Speed: 60% (minimize wear for a smaller design)
Power: 55%
My line size is 3pt and I etched two passes at the above settings in raster mode.
daewootech says: Mar 5, 2013. 3:20 PM
I used this process for lasering a piece glass for my class of then which i sandblasted through the lasered part to etch a image onto a piece of glass.
the5thfool (author) in reply to daewootechMar 6, 2013. 6:00 PM
Interesting, the sandblasting didn't affect the stencil?
Tachyon says: Mar 4, 2013. 12:16 AM
Very impressive. This is KISS engineering at it's finest. Nice work.
the5thfool (author) in reply to TachyonMar 6, 2013. 5:59 PM
Thank you! I think the value of super simple Instructables is under-rated. I'll try and add more soon. XD
GorillazMiko says: Feb 28, 2013. 1:28 PM
This came out great! I have a couple of film cameras that have leather on the body, so I might try and etch some designs on a few of those.
Thanks for sharing!
GM
the5thfool (author) in reply to GorillazMikoFeb 28, 2013. 5:13 PM
Thank you! I'd love to see your cameras when they're done!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
