3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High Current Flickering Pumpkin LED Driver
Use a LED Tea Light to Drive High Current LED's that is simple and easy to make.
Designing the circuit that produces a true real looking candle-flame effect is very difficult to accomplish. I wanted to make a simple and quick way to drive higher current LED's without all the hard work. I was looking at a LED Tea Light at Michael's Crafts Store and the realization came to me why don't I just connect the flickering LED Tea Light to a drive circuit that can handle the higher current loads to produce a high current LED Driver. The hard part of the circuit design was completed by the purchase of the LED Tea Light that cost a couple of dollars.
Step 1Take apart theTea Light
To open the Tea Lights you cut with a knife 1/2" in from the bottom until you cut through the plastic so the top will come off. With the top off I soldered a wire to the (+) anode lead of the LED, this wire will drive the flickering effect of the high current driver. To locate the plus (+) side of the LED lead is to use a digital multi meter with the Tea Light turned on. I solder a wire to the negative side of the battery so we have a common circuit ground. In the picture the red wire is the (+) and the white wire is the negative battery terminal.
GE (General Electric)
Flickering Tea Light LED
#362298 (One Tea Light)
#399217 (Six Tea Lights Value Pack)
3 comments
Aug 26, 2009. 10:32 AMPaddy21 says:
Are you sure the Tea Light varies the voltage and current? I would sooner believe it creates a psuedo random PWM output to the LED. Meaning, it turns on the LED for random amounts of time. I can't see from the picture what exactly makes up the Tea Light circuit to say one way or the other though.
Jan 24, 2009. 7:36 AMHillhiker says:
I have been looking for something like this for a while... this seems to be a very nice approach to the flickering LED problem in that the lumen's or volume of light if you will can be adjusted... also no PIC and ATMEL devices need to be dealt with... wondering how a couple Cree-XR's would look... breadboard time... Thanks
Jul 21, 2009. 7:49 AMcorey872 says:
Neat circuit. The latest round of tea lights I bought, the 'flicker' was built right into the LED as opposed to being a separate circuit board as with the older designs. But this should work just about the same. I've used a very similar circuit and some 150mA 'straw hat' LEDs (ebay) to really light up some pumpkins. With the LEDs is you can light up plastic, foam, and all manner of otherwise 'flammable' pumpkins and decorations. Though I also have to have several real pumpkins with candles...just have to have the 'burning pumpkin' smell in the crisp fall air to really feel like Halloween! On a side note, experiment with the variable resistors, then swap out for cheap/small fixed resistors of the same value to really miniaturize the circuit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:mark-mark
