Step 2Circuit Design
but to make LED's flicker like the Tea Lights LED. A good starting point for R1 is 50K ohms and R2 is 20K ohms. The Output LED driver 2N3906 has a maximum IC of 200mA and that can be replaced with PN2907 for a maximum IC of 800mA.
The resistor Rx can be changed to control the current and voltage through the output LED's. I used 471 ohms for Rx to produce a maximum current of 25mA in each LED.
You can install many output driver sections together to produce more lumens of flickering light.
The circuit design makes a simulated candle flame effect to drive high current LED's, other high current loads, or HBLED, etc.
comments
Add Comment
Add Comment
