Wanted to share the circuit and also the method of construction for the lighting enclosure which worked out quiet well.
There are many variations that one could make here. With a higher voltage battery pack, the circuit will drive at least 2 more LEDs (6 in total) or less could be used. Different optics or mountings could also be used.
As there is already quiet a detailed work log on NoBMoB please check there: Rob's Homemade LEDs.
Have just included a couple of brief steps, please visit the above for the details.
Remove these ads by
Signing UpStep 1Circuit Design
The circuit below uses rudimentary logic to turn of the main LEDs with the simple flasher and 'low' battery warning - in effect this 'blinks' the main LEDs when the battery is getting low.
A second voltage comparison turns of the main LEDs when the battery pack voltage is getting too low, to prevent over-discharge. What's good here is that in doing so raises the input voltage and we get a feedback loop that actually causes the main LEDs to dim nicely rather than cut out abruptly.
comment
Add Comment
Add Comment
![PLAE - Portable Led Angel Eyes [ +1000lm ]](http://img.instructables.com/files/deriv/FAU/PMIX/GWHN3OBW/FAUPMIXGWHN3OBW.SQUARE.jpg)
