3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High Speed Flash Photography
This is a picture of a screw driver mid bounce.
After reading about high speed photography in a magazine I was inspired to dig through my closet and see what I could come up with. I used a home made make-screen to trigger the flash while my digital camera was waiting with the shutter wide open.
It looks like I just stuck the screwdriver into the carpet, but I dropped it onto the makescreen. The second picture is of an airsoft pellet going through the makescreen.
Step 1Tools and Materials
Tools and Materials
Materials:
Disposable camera
wax paper
aluminum foil (Thinner the better)
wire
momentary switch
alligator leads
Tools:
solder
soldering iron
wire strippers
clothes iron
ironing board
screw driver
airsoft gun (at least thats what I used)
The great thing about this project is the low costs involved. I went to a photo finishing place and asked if they would give me the leftovers and they happily gave me three.
I wanted the thinest aluminum foil available, so I picked up the foil and the wax paper at the dollar store.
80 comments
1-40 of 80next »
Apr 5, 2010. 8:22 PMDefault117 says:
I've shocked myself with one of those, decided I didn't want to be shocked again and shorted it out with a screw driver. Scared the crap outta me! Ever since then, whenever I get surprised it feels like a nine-volt on my tongue.
Mar 19, 2009. 5:53 PMalextricity says:
I play with power lines (a 100 KW equivalent) :D
Mar 7, 2009. 7:29 PMtanmanknex says:
If you go to Wal-Mart then they give you a big bag with about 10-15 used disposable cameras, FYI.
Aug 12, 2008. 4:09 PMhomebowyerboy says:
Just be carefull cause it does bloody hurt, though not as much as 37 of them in series, that feels like bloody hell! (Trust me, i know from experience)
Apr 21, 2008. 9:39 PM-Aj- says:
AH, so thats how you do high speed photography, i was wondering why bright super quick flashes where important. so you leave the shutter open in very dark conditions then have a quick, bright flash. cool.
thanks for the instructable.
also
mains power will kill you good. you may have been lucky and standing on a chair or something so you where not grounded and the leakage through air was enough to light the bulb.
you can get small screwdrivers used for testing mains for power. it has a neon light in it, and a big ass resistor. you put your finger on the back end of the screwdriver and put it into the wall socket. you do not get hurt because of the very low power.
while it is current that kills you, you need the voltage to break down the resistance for it to be able to do that. so 12v @ 100A will not kill you as your bodies resistance is too high to allow that kind of current to flow at that voltage.
V = IR if your skin resistance is 10k ohm. then 12 = 10000R
R = 12/ 10000
= .12 mA
enough to give you a tingle
however once the resistance has been broken down then the more current will flow, which is why if you hold a 12v plug pack connector to your chin it will slowly start tingling then get more and more.
so you cant have the high current unless the voltage is there, as the body isnt a particularly good conductor. (also if your in a bathtub and drop a hairdrier in, you are safe unless you are touching the taps or the drain.) for same reason :D
Aug 12, 2008. 12:43 PMSpokehedz says:
I don't see one mention of mains electricity mentioned in this article other than what you mentioned. The cap in there is big enough to give you a shock but not enough to kill you. Been zapped by these many times--made one of them into the spark generator for my Potato Gun, as a matter-of-fact.
Apr 10, 2008. 5:51 PMS1L3N7 SWAT says:
Awesome, this would be a good way to make a chronograph! I was thinking the other day of how to make a simple chrono using to sheets of paper spaced exactly 1ft apart and secured in a frame of some sorts. Then take a cheap stop watch and rewire the buttons for the start and stop to the paper. I was thinking of taping a piece of alluminum foil to the paper, just a small piece like 1in by 1in and place the "trigger" leads near it. When you shoot the first piece of paper it moved it just enough to trigger the start and when it exits the second it triggers the stop. Look at the time it took to travel 1ft, then do the math.
May 26, 2007. 9:47 AMThermionic says:
For those at the top arguing about 300 volts and it's level of killitude. Current kills, not voltage. Static from a door knob can be anywhere from 20, to over 100,000 volts. The current is infinite, but since the discharge is instantaneous, You barely feel it. The capacitor on this camera is 300 volts ( or in that neighborhood if you actually test them) If you put your finget across that, you'll probably get a little burn. BUT if you were to put one finger from each hand on each lead, your heart is now directly in the path of current flow. Which can cause arrhythmia, or deadness. I am by ne means arguing with Vendigroth, people have survived lightning strikes with very little ill after effect, but those folks were the exception rather than the rule. People more often get hit and are either severely impaired physiologically, or severely impaired being alivealogically. Is this camera gonna kill you, probably not. CAN it kill you? most certainly.
Feb 3, 2008. 11:06 AMThermionic says:
Wrong, the static charge is infinite in current, the amount in reserve, in a particular static field is what determines killability. If you just want to use the term static(not moving) then the air around a turbine at an hydroelectric facility is perfectly safe. The static on a doorknob, is of such a small magnitude, and the field so small, that it discharges instantly. Since it has no natural resistance, the current is infinite for the microsecond it flows.
Feb 11, 2008. 7:16 PMThermionic says:
you know what, you win, I'm wrong, I have no further interest in engaging in this debate. thanks
Sep 7, 2007. 7:55 PMkillerjackalope says:
2 problems though the metal isn't exactly helping the case in saving you from the lightning, it has to be shoulder to shoulder for the cap idea, however having recently been changing lightbulbs and gotten electrocuted again I can safely say 240VAC at 50hz (UK mains) can't kill you (I don't know the currents though) but you can light a bulb with one hand, in fact it may have saved my life, as it would have hit me across the chest for the second time in a month. In any risk of electrocution I suggest you remove your non electrocutable hand off the ground as that way your less like to get dead and as for the caps through the hands, well it's dumb to deliberately get shocked or allow your self to be but hey aint deadlylong as its one hand
Jan 6, 2008. 12:01 AMjinventive says:
240 volt UK mains can easily kill you as its currents are around about 13 amps that is certainly enough to kill you. My dad has been shocked many times by 240 volts but luckily hasn't been killed, however, these were some very lucky cases where the current didn't go across his heart. If that happened he would almost certainly been killed.
Feb 4, 2008. 12:32 AMshaunak says:
If you have over 0.1A flowing through your heart, your heart goes into something called "fibrillosis" [please corrct my spelling]. What basically happens is the bodies natural pacemaker is also giving out tiny current pulses to "clock" your heart. If an external "clocking" pulse is applied, it misses a clock cycle and you get an cardiac arrest. [Quite a low margin for error that ;)] Here's why you survive those small shocks: The torso's internal resistance is widely accepted to be 10Kohms, but the path across you skin is has much lower resistance. 800ohms when wet [with sweat] So much of the current never actually flows though you heart. But if it has no other path, ie you connect your heart in series, well then your sorta dead.
Apr 21, 2008. 9:45 PM-Aj- says:
yes! jumper leads across youre nipples should do it!
Apr 23, 2008. 2:35 AMshaunak says:
LOL
Feb 4, 2008. 12:35 AMshaunak says:
Please forgive my spellings and blank links on the post above. I was in a terrible hurry and didnt know that enclosing in square brackets caused text to be auomatically hyperlinked.
Jan 6, 2008. 5:29 AMkillerjackalope says:
The main thing I have trouble understanding is the fact that a tiny voltage hand to hand (as in across the chest) could kill people but some people get away with it... I've been hit hand to hand a few times and nought's happened to me...
Jan 6, 2008. 9:56 AMjinventive says:
Yes, some people are very lucky that they don't get killed by getting electrocuted.
Oct 6, 2008. 9:53 PMDerin says:
like me,got shocked 3 times and im 10
Jan 3, 2008. 7:40 AMramses says:
since we are sharing about getting shocked, i got shocked by 4 of these capacitors in the same finger. i felt it all the way to my bicep (or lack of). it hurt like a MOFO (mother f*cker). it aint deadly but it still sucks! if you like pain, you have some kind of problem, please see a profesional. (i don't count lol)
Jan 3, 2008. 7:56 AMkillerjackalope says:
I never got the idea of hurting yourself deliberately but I like taking risks with painful gambles, a completely different philosophy but if you do a similar thing with no risk just getting hurt then you never fail...
Apr 21, 2008. 9:47 PM-Aj- says:
try copping an electric fence you your ear, a cattle one. feel like a fking sledge hammer.
Apr 22, 2008. 3:02 AMkillerjackalope says:
I sat on one for like five minutes and then my leg touched wires, I fell off and got my hand shocked aswell...
Jan 6, 2008. 1:34 PMramses says:
sorry if i got upset, but it should be noted that your first mistake could be your last. the point is that even if something doesn't kill you, it isn't good! that could have killed me if i touched it with my other hand. also, current kills, not voltage. 1ma- "tingily" 5ma - "ow" 10ma- "$h*7!" (no longer safe) 30ma dc - "I can't let go" and "$h*7!!!" subjecting yourself to pain isn't cool!
Jan 6, 2008. 2:07 PMkillerjackalope says:
I was agreeing but saying there's fun in risks, mostly with physical and mechanical things like 'how fast can I really go' thoughts or those electric shock games, but that's a competition (which I win quite often...) I have the don't let go mentality when being competetive. Though this kind of list works well for drinking, which isn't much different... Tingly Wow Shit (I fell over) Cant let go of the handrail and shit lol I see people drink themselves to death in the same way that people have the shock games that are just hurting yourself (even saw them combined)
Jan 13, 2008. 3:00 AMmbainrot says:
With the electrocutions,
@240vac 50Hz (Australia)
30mA to 50mA = heart stopping, POSSIBLE REVIVAL (no guarantees)
100mA + = toasted central nervous system = dead, i.e no revival
Thats what i learned anyway...
As with the instructable SWEET :P
What i did with my rig was cut a hole in a box and sticky taped the foil to the box, then sticky taped the wire to the box.
My flash is an external flash (slave)
See the pic for my results, (took me several tries to get to that photo)
Jan 31, 2008. 3:32 AMmbainrot says:
Its an "Air Blasters" dart (that looks like a nurf dart), i re did the photo so bellow is a more recent/more refined picture :D ~~ Enjoy ~~
Apr 8, 2007. 8:49 AMThat Hurt This Time says:
Cmon, 300 volts? Static electricity shocks you at around 12000 volts. Its not the volts that kill you, its the amps anyway. I think the highest voltage that someon has been shocked at is around 300000 volts.
Dec 16, 2007. 1:45 AMgrahamslawson says:
i took apart a digital camera and got shocked by it. My friend took apart a digital camera and ha as 2 spots on his finger where he shorted the cap I can tell you it bloody hurts He can tell you it bloody hurts That is why you short the cap.
May 4, 2007. 10:36 AMVendigroth says:
lightning's been known to leave survivors in one piece, able to move and speak and still technically alive. Actually, the best defense (actually, no, you're just as likely to get hit) against a lightning bolt is to wear a gold necklace. All the energy from the strike goes into boiling the gold away, not blowing you to cinders, OTOH, you get a necklace-shaped scar.
Jan 31, 2008. 4:14 AMlasersage says:
It would only go into the necklace if that was the easiest path to ground. Electricity is lazy, always looking for the path of least resistance. Admittedly some may flow through the very nicely conducting gold, but chances are, that it is not grounded and you are. Hence you're going to get most of the shock . As for peoples previous comments, it is indeed true that current is the killer. People percieve that low voltages and DC are safer. This is WRONG! AC often causes a spasm, whereas DC often causes you to lock you muscles (unable to let go). 1V will kill you if you make a suitably good contact (low resistance, hence high current). The real danger with high voltage is that it can penetrate your skin. This is why low voltage is often considered "safe".
Dec 11, 2007. 4:17 PMVulcanator says:
my friend was struck by lightning... in a lake
Nov 2, 2007. 6:35 PMdajjhman says:
On the matter of freaking lightning and electrical shocks. First: it takes only 20mA to stop your heart. Second: in order for it to stop your heart, their just has to be a possible path including it (hand to hand; head to toe; hand to opposite wait etc etc...) Third: the gold necklace is a myth, and a dangerous one too. The necklace cannot provide a ground for the current, so electricity wont even flow through it! Which leads me to #4 Current likes to flow from an area of charge, to an area of no or opposite charge...I work with 50,000 Volts on a daily basis and I can say even if it is not the opposite electrode that you are connected to, it is still likely to zap through you [think of it as water, you have a box filled, suddenly connected to a box that is empty by a pipe on the bottom; naturally it evens out the amount of water]
Aug 10, 2007. 11:54 PM-insertnamehere- says:
I finally got mine to work ..with the first makescreen I made I didn't Iron it long enough...the second one I made worked only once, and I got this picture of an airsoft pellet hitting it. (Having 330 volts run through your hand feels really weird.) thanks for this instructable, it was really fun. maybe I'll get some better pictures when I make a new screen.
Aug 11, 2007. 11:37 PM-insertnamehere- says:
here's better pictures :) the first picture is baking soda being shot off a paper cup the second one is water being shot of a paper cup the third water off the top of a cup the fourth is baking soda off the top of a cup(not very impressive....) the fifth is baby powder off the top off the cup I found the pictures come out better if you put a piece of paper over the flash, so it diffuses the flash a bit
1-40 of 80next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:phinch
