3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
High Speed Videography for Beginners.
Everyone I have met and talked to share one thing in common: the desire to own, or at least play with, a high speed camera. Though I doubt that many of the people reading this have a high speed camera of their own, it is my wish that the few who's dream came true will find this guide useful. This is a guide based on personal experiences and trial and error.
Step 1The Camera
The Camera
This guide is based off of the Casio EX-F1. It is a $1000 multifunction digital camera with options of 300, 600, and 1200 frames per second. At the time I write this, it is the cheapest consumer high speed camera available. To those wishing to buy a high speed camera; save, save, save! I saved since the fifth grade to buy one of these puppies.
Here is a walkthrough of the different frame rates in order of speed. Changing the fps is simple, press MENU>Quality>HS Speed> 300, 600, 1200, or 30-300.
300fps:
This setting has the largest viewing window (512X384 pixels) and requires the least amount of light. It has the slowest frame rate, meaning the playback footage is faster than than 600 and 1200 modes, but slower than real time (which is around 60fps).
600:
(432X192)
Just like Goldilocks, this setting is "just right." It has a manageable viewing window and does not require an excessive amount of light, making it perfect for larger actions such as a football tackle. The playback footage is pleasingly Matrix-time slow.
1200:
(336X96)
The shutter moves fastest in this mode; it opens and closes 1,200 times each second. Although it has a very narrow viewing window, this mode produces the best end results. Recordings can last about fifteen seconds before frames are lost, resulting in jumpy footage.
30-300:
(512X384)
The thirty-three-hundred mode means that the camera is filming at regular speeds, but with a turn of the ring, switches to 300fps mode. Another turn of the ring brings the speed back to 30fps. The ring, located just behind the lens, has three functions: zoom, focus, and CS fps (camera shutter fps). The default setting is "off;" turning the ring does nothing whatsoever. To change this, press MENU>REC>Ring Setup>CS fps.
I highly recommend buying a lens filter/protector. These nifty little devices screw over the lens to protect it from harm (you are blowing things up, remember). If the lens protector becomes scratched or damaged, it is easy and cheap to replace; as opposed to a $1000 camera lens.
41 comments
1-40 of 41next »
Dec 9, 2010. 7:02 AMj.middlefinger says:
I have the Casio EF-XH25 ($300 new in box on eBay) myself. It's like the EX-F1 but doesn't have interchangeable lenses. The unit's lens is very robust though, and for my purposes, it does quite nicely.
I have been using this camera mainly as a means to analyze human athletic movements in order to improve my horrible hockey playing, so I shoot mainly at 420 fps to keep the resolution nice and high. You can see some of the videos I took at the following links - just keep in mind that the first two were taken from all the way across the rink from the balcony seats.
http://gallery.me.com/j.middlefinger#100174&bgcolor=black&view=grid
http://gallery.me.com/j.middlefinger#100171&bgcolor=black&view=grid
http://www.youtube.com/watch?v=9cJkTsf9H94&feature=youtube_gdata_player
Sep 14, 2010. 11:26 PMBoppo3 says:
do you use any software to slow things down?
Aug 17, 2010. 11:20 AMwii552 says:
there isn't REALLY a shutter moving during filming, is there? i thought it was just images being saved one after another. Some video cameras don't have shutters!
Aug 15, 2010. 12:52 AMClayton H. says:
Here's a more cheaper version of the $1000+ Casio mentioned
Sep 16, 2009. 12:40 AMKryptonite says:
Wow that's amazing, but what's the bb gun used?
May 10, 2009. 6:35 AMDerin says:
There is also a way to do high speed using CamStudio.Sometime soon I will post a filming of a Gmod explosion.
May 10, 2009. 6:53 AMDerin says:
It will be a cannon shooting an explosive barrel.The flaming barrel shoots out and blows up in touchdown.
Apr 20, 2009. 1:02 PMtemp says:
Maybe if you put a piece of paper or something over the tungsten light it will give a more natural look.
Apr 20, 2009. 1:37 AMthepaul1993 says:
i want to get one of those cameras. but for now i have my phone that records only 120fps
Apr 19, 2009. 1:44 PMzmatt says:
What is the resolution at the various FPS? Thanks
Feb 9, 2009. 12:53 AMHolden_vy_s says:
Hey Spl1nt3rC3ll, can you record a video of a lit match dropped onto a small puddle of petrol (gasoline) and/or a puddle of alcohol ( AKA Heet, methylated spirits )? Anyone know of a website to download shots similair to that? I reckon that would be a very good high speed shot, especially from a 45 degree angle. Very good Instructible BTW.
Mar 5, 2009. 11:07 PMHolden_vy_s says:
Great, hit me up when you post them :)
Mar 25, 2009. 6:21 AMHolden_vy_s says:
Awesome clips! the ignition of gasoline or heated alcohol would be the best though, you could see that little froomph upon ignition. Thanks for that, i wish i had the money to afford one of these cameras.
Mar 21, 2009. 8:58 PMbenthekahn says:
I suppose LED bulbs would work well, assuming they were diffused.
Feb 12, 2009. 11:51 PMjcl236 says:
I have been looking at buying one of these, probably the EX-FH20 but I would really like to know what the picture and "HD" 720P video looks like. Casio doesn't seem to have a retail store where they sell these cameras, so I was wondering what you thought of the picture quality and settings and if there is a store that might sell the camera that I don't know about so I can check it out. Thank you.
Feb 15, 2009. 10:56 AMjcl236 says:
Thank you for the pictures, i was hoping they would look better but I expected the camera would be lacking somewhere
Feb 15, 2009. 7:54 AMbumper44 says:
Wow you put a lot of work into this instructable! Thank you!
Unrelated but cool video below.
http://www.youtube.com/watch?v=lXDLS1ZPVw4
Feb 12, 2009. 10:50 AMatanguay says:
Does anyone know of anything cheaper that compromises on the frame rate a bit? I need a camera that does about 90fps or more, but not the 300 and more that this camera can do. But I need multiple cameras...this is motion capture project, so you need multiple views, which would be really pricey with this camera. Thanks for any ideas.
Feb 12, 2009. 12:44 PMclide says:
The Philips spc900nc webcam claims 90 fps, but I've never actually got it to go that high. I'm not sure exactly what kind of motion capture you are doing, but if you are just looking at the motion of specific points then you can strap infrared lights to those points and use the wiimote which has a refresh rate of 100 Hz supposedly. I can't verify that myself. Then there is the Casio EX-FH20 which is a little cheaper than the EX-F1. They are also coming out with some additional high speed stuff later this year including the EX-FS10 which is supposed to go for $350
Feb 12, 2009. 4:47 PMatanguay says:
Thanks Clide! Good stuff. The idea is to capture footage to use with a program called Movimento.
Feb 12, 2009. 1:02 PMclide says:
Another tip for the montages. Changing the playback rate for different parts of the same clip can help keep things going. Slow things down to 15 fps or so for exciting moments like impacts. For the less exciting stuff like objects flying through the air in a predictable way you can speed it up to twice the speed.
Here is a video I made that uses that technique: Youtube Link. A lot of times it's not even very noticeable to me. Probably not noticeable at all for people who don't know what the original clip looks like.
Feb 7, 2009. 3:32 PMKiteman says:
Is there a special reason why the frame gets wider and wider as the rate goes up?
Feb 12, 2009. 10:35 AMjridley says:
My bet would be that they don't have enough data bandwidth throughout the system to handle full res at higher frame rates, so they chop the top and bottom out. The fact that they're throwing out lines of the sensor rather than data to the sides indicates to me that probably the bottleneck is in getting data off the sensor fast enough.
Feb 8, 2009. 12:31 AMfrollard says:
The shutter physically does not move, it is as open as it can get (think of the lighting conundrum) - They need all available light. Look directly into the lense when shooting a video, you can usually see it (shine a dim light in).
Feb 8, 2009. 3:00 AMKiteman says:
And so was that one. I think it's because you're the author of the 'ible.
Jun 6, 2009. 9:44 PMDerin says:
There's no shade on his comment.
Feb 7, 2009. 3:44 PMn8man says:
Yes, the frame is actually getting shorter as the speed increases because the shutter can only open so much in that very short period of time.
They're not using a mechanical shutter.
Feb 12, 2009. 6:13 PMn8man says:
The camera that he uses does have one.
Feb 13, 2009. 5:19 AMjridley says:
Yes, it does, but it doesn't use it at the high frame rates or movie modes, only in single-shot modes.
Feb 8, 2009. 12:21 AMfrollard says:
I dont believe the shutter physically MOVES at that pace - or do you hear a rather loud buzzing noise coming from the camera? The frame'rate' is achieved by having the cpu scan the ccd at that speed. The frame has x*y pixels. to increase shutter speed the ccd only scans less and less of the pixels. Traditionally they just reduce resolution uniformly, but reducing it to widescreen has more appeal for the new widescreen HD market. Look at it this way, it can record 'huge' HD video from all the pixels at once, or extremely fast video from a very small portion of the pixels. Since it scans in horizontal lines, row by row, it further makes sense to scan an entire row, at a time, and simply scan less rows (easier ccd math and less biasing from the unused transistors). Great writeup!! I want one of those cameras!
Feb 7, 2009. 2:24 PMdung0beetle says:
great instructible! Very informative!
Feb 7, 2009. 1:50 PMsammyBoy says:
How do you ever get anything sensible done in your life when you own one of these. I'm going to have to pretend I didn't read all this so that I spend some time with my sons rather than filming them at 1200fps. I just didn't think the technology was this accessible to us mere mortals. I'm very envious - have fun.
Feb 7, 2009. 1:40 PMSunbanks says:
Wow, those are some awesome videos! I liked the step about the lighting and how you shouldn't even think about trying to film something in pitch black :D
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
79
Author:Spl1nt3rC3ll
I enjoy videography and art in general. My specialty is directing and editing, and I have multiple films under my belt. As you can tell, I prefer to be behind the camera rather than in its sight. I am...
more »
